Old 05-04-2002, 04:04 AM   #1
primer67
primer67's Avatar
Post IN AZ? need help! will pay!!
I am in phoenix, and have a bent axle. recieved new axle from randy. I started on the process to replace it and found that the gears were all messed up! - Today i located a rearend -- the guts are all I needed -- I removed the guts- by the way, this one has 32 teeth on the ring ? what ratio? - anyway I will exchange the rings on the carrier, and replace the unit -- One problem....
the pin in the carrier will not push out!! - the PO f@#ked it up big time! It is currently 2:02 am, and I have been trying to fix this since 7:00 last afternoon. I am thinking a torch will do this - If I can't get this done, I will sit and grind dremel wheels until I cry. - If anybody can help me, I will make it worth (really worth!!) their time. I can be reached at 602-299-7205
please Please please respond!!
thanks.
1967 C-10 Longbed
rollpanned front&back
Cowl induction hood
'91 5.7 liter/vortec heads, 700r4 trans. holley headers,
holley fuelpump,
holley mufflers. converted to edelbrock performer/carter 625
hei/advanced recurve
MSD 6A ignition box.
Accel supercoil
Accel custom 8.8 wires
5 bucks a plug even!
faster!!!!!!!!!!!!!
soon to be lowered "a little" looking for a good tonneau cover.
primer67 is offline   Reply With Quote
Old 05-04-2002, 04:20 AM   #2
68 Suburban
68 Suburban's Avatar
Post
What type of help do you need?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-04-2002, 04:25 AM   #3
primer67
primer67's Avatar
Post
I think I'll need to cut that pin out with a torch. pretty much that's all I need help with (famous last words)
Old 05-04-2002, 04:31 AM   #4
68 Suburban
Post
Well do you have a torch? What help do you need?
Old 05-04-2002, 08:06 AM   #5
Desert Rat
Desert Rat's Avatar
Post
did you take out the bolt?
Desert Rat is offline   Reply With Quote
Old 05-04-2002, 03:48 PM   #6
primer67
primer67's Avatar
Post
I dont have a torch - I took out the bolt the pin is so warped that it has mushroomed around the spider gears -- they have their own tracks on the pin to ride on basically.
ttt
Old 05-04-2002, 04:07 PM   #7
Fast68Chevy
Fast68Chevy's Avatar
Post
32 ?
should be 41 or 43 if is 64-72 axle..
lok on the very edge of the ring gear while tiurning it you will see stamped in numbers, wil say sometihng like 43:13 on it, divide smaller into larger ot get you ratio. i have torch, too bad im not out there, i really wish i was!!! sniff sniff**
am gonna call you in a few,
R
[This message has been edited by Fast68Chevy (edited May 04, 2002).]
Fast68Chevy is offline   Reply With Quote
