Old 01-04-2007, 01:55 AM   #1
ClassicRedneck05
ClassicRedneck05's Avatar
Exclamation Windows in my 72
ok so after my rewire my next thing was fixing the windows now before i bought the truck the guy said he replaced the grgulater which i belive is true it looks new to me BUT the bottem channel that the window sits on keeps getting in a bind and also if i roll it down the windo does not go down i have to pull it down and on the pass side its hard for me to get it to roll down HELP
ClassicRedneck05 is offline   Reply With Quote
Old 01-04-2007, 02:02 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Windows in my 72
Is everything lubed good? If not, try some white lithium grease spray on all moving parts.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-04-2007, 02:24 AM   #3
ClassicRedneck05
yeah all is good but on the driver side the window doesnt go down when i roll it down i have to roll it down then pull the window down
Old 01-04-2007, 03:16 AM   #4
Bishops Trucks
KEEP ON TRUCKIN'
Does it roll up without any help?
JIM
Old 01-04-2007, 03:21 AM   #5
ClassicRedneck05
ehh not anymore lol it binds up i think it may be the felt
Old 01-04-2007, 03:34 AM   #6
Bishops Trucks
KEEP ON TRUCKIN'
The post for the wing window that goes down inside the door. Could it be cocked over towards the glass causing it to bind. Try loosening the screws holding it inside the the door and roll the window down.
JIM
Old 01-04-2007, 10:11 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
I'm not sure I can explain this good enough but I'll try.
There are two rollers on the arms of the window regulator that roll in the channel at the bottom of the window. There is also an arm on the window regulator with a roller on it that rolls in a channel on the inside of the door panel where the upholstery fastens. The roller came out of this channel on my truck and it caused the same problem you are having. If you have the door panel off put your fingers inside the large factory hole, pointing up (back toward the latch) and you should feel the arm and channel. I had to completely remove the regulator to replace the roller on that arm, and to make it easy it is a two person job.....
LockDoc
Leon
