01-04-2007, 07:55 AM | #1 |
Removing Dash Pad Cover
I am pretty sure I got one of these el cheapo plastic dash pad covers over my dash pad on my 69 C10. I want to take it off and replace, but cannot find any screws. I take it that it is glued on? Also, where are the screws to take off the actual dash pad? I figure they are under the dash pad, but I don't want to destroy it looking for the screws. Thanks.
01-04-2007, 08:00 AM | #2 |
Re: Removing Dash Pad Cover
yeah they are underneath the pad. studs go through the dash. you get to the nuts from backside under the dash, i cant remember how many though
01-04-2007, 08:05 AM | #3 |
spend all day reaching under dash or take the glove box liner and the cluster out and presto you will get to the speed nuts that hold her together
01-04-2007, 08:24 AM | #4 |
Thanks guys. Looks like there is no easy way out of this one. I think I will order the new dash pad and see how many studs, and where they are positioned before attempting anything.
01-04-2007, 10:12 AM | #5 |
That's a good plan
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-04-2007, 04:49 PM | #6 |
its all about the +6 inches
you'll really hate the job if you have A/C.
Honestly, when I did mine, none of the nuts went on, just the screws, and no one would ever know either. |
01-04-2007, 05:50 PM | #7 |
I am a Referee of life.
Be careful tightening the nuts back down.If you overtighten one it will cause the pad to not lay flat.I found that a 1/4 in socket set with extra extensions and swivels helped a lot.Going back I put a small piece of double sided sticky tape inside the socket to help hold the nut.(Rub it with a bit of dust or lint so it sticks to the socket and only holds the nut).I don't have AC but I can tell you it would be a pain to get to with it since it is without.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 01-04-2007 at 05:51 PM. |
01-05-2007, 11:22 AM | #8 |
Sandwich: Club
It may not seem like it, but you can save time and maybe a broken or cut up wrist if you pull out your dash bezel (including headlight switch), center a/c vent and radio, and your glovebox.......
01-05-2007, 11:24 AM | #9 |
67 is sold
I was suprised to see how that dash pad was attached on my 67 - that thing wasn't going anywhere
