Old 01-04-2007, 11:01 PM   #1
ncC20
8 lug to 5 or 6 conversion
Ok heres my problem i have a 72 c20 truck.Which is an 8 lug and i cant find any nice wheels for. So i want to convert it to a 5 or 6. My ? is what parts do i need to do this. Is there a factory set up that will bolt up
ncC20 is offline   Reply With Quote
Old 01-05-2007, 12:27 AM   #2
poorboy
poorboy's Avatar
Re: 8 lug to 5 or 6 conversion
You can get a rear end from a 1/2 ton. In the front you will have to swap arms and spindels.
poorboy is offline   Reply With Quote
Old 01-05-2007, 06:01 PM   #3
ncC20
Will only the 67-72 spindles fit ?
Old 01-05-2007, 08:42 PM   #4
manimal
manimal's Avatar
No. You can bolt on a set of 73-87 uppr/lower arms and spindles from a 1/2ton 2wd. If you have leaf springs I think you can also find a 12 bolt rear end from same 73-87 1/2 ton truck and it will bolt in.DONT QUOTE ME ON ANY OF THIS FOR I TOO AM LEARNING THE SAME!!
manimal is offline   Reply With Quote
Old 01-05-2007, 09:14 PM   #5
corn
Isnt this truck a 3/4 ton?
corn is offline   Reply With Quote
Old 01-05-2007, 10:41 PM   #6
1969K10
1969K10's Avatar
I don't think your looking much - JMHO
It'd be easier & cheaper to find some nice 8 luggers...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-05-2007, 11:01 PM   #7
72slam
72slam's Avatar
I just changed my 72 c20 to c10. I took my old rear axle to the junkyard and they gave me an even trade for a 1975 12 bolt rear. The front I used ECE drop spindles designed for c20 to c10 conversion. Bolts right in, then use standard c10 brake rotors. You can use existing calipers.
72slam is offline   Reply With Quote
Old 01-05-2007, 11:48 PM   #8
poorboy
poorboy's Avatar
I would think you would have a better rim selection with all the newer 3/4 tons on the road. You see everything from stock size replacements to 22's on them.
Old 01-06-2007, 01:04 AM   #9
Toms Truckin
Toms Truckin's Avatar
I have found the same problem for my 72 8 lug. There are a few rims out there that look decent for it. But, with my axle stubs sticking out so far, I couldn't get a single dust cap to fit over them. I will be doing the same thing to my truck. There's obviously more options out there in the 5 lug world, they are definitely sportier. Plus I am looking forward to ditching my 4.11 rear end for something a little more gas friendly. And I'd get a good chance to clean it up before installing it.
72 GMC Sierra Grande
Toms Truckin is offline   Reply With Quote
Old 01-06-2007, 01:10 AM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
Rim selection for the 8 lug is poor. And the 4.10 gears are lousy.
I would go to a junkyard and get parts off a 73-87 1/2 ton. The entire front crossmember and steering gear. It's almost a bolt-in. From the back, get the differential and springs. This will have your truck riding on 1/2 ton suspension with disc brakes up front, power steering and power brakes (if you don't have them, get the parts) and better gearing for driving. You will also need a u-joint to go from your 3/4 ton driveshaft to the 1/2 ton, but any good auto parts store should have that.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-06-2007, 02:16 PM   #11
ncC20
Hey thanks form the info guys. I had been told by a guy b4 that the 73-87 would work but wasnt 4sure he new what he was talking bout. Hey corn u have ne more pics or info on the two pics u posted i really like what i see
