Old 01-05-2007, 09:26 AM   #1
75sierraclassic
75sierraclassic's Avatar
Where to mount tach?
Anyone have any pictures of where they mounted a tack in their truck? Its not going in the dash or on the dash, so I was thinking of mounting it either on the column or at the bottom of the dash below the cigarette lighter. Anyone mounted one to their column?
75sierraclassic is offline   Reply With Quote
Old 01-05-2007, 11:24 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Where to mount tach?
I mounted mine and my son's on the driver's 'A' pillar, by using a screw that was already there for the trim piece. This put's the tach just above the dash on the left hand side and it is just below eye level. I used a piece of "Mill-stock" aluminum and drilled it to have the screw go through it, then I tapered the end that is close to the windshield so that it would follow the contur and hold the bracket solid. The tach is then bolted to the strap and faced out to the driver. The wire for the tach is fed down past the dash at the end of the padding..
Old 01-05-2007, 11:58 AM   #3
75sierraclassic
A pic would be great if you have one.
Old 01-05-2007, 12:15 PM   #4
HotRod73
HotRod73's Avatar
email me @ wilbanks89@cox.net i have a pic u can see
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 01-05-2007, 12:16 PM   #5
HotRod73
HotRod73's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=220815
ive got better pics if u email me...
Old 01-05-2007, 12:16 PM   #6
Prerunner1982
Prerunner1982's Avatar
I mounted mine on my column just ahead of the tilt and the shifter. The wires were run down the top of the column and under the dash with the column. It only covered up the 2 warning lights and maybe a bit of the gas gauge. I used a hose clamp to mount it. Not the prettiest thing to use but it worked. It also puts it in the same area as the other gauges so that it is easily seen while checking the others.
If you mount it under your ash tray it is out of the way to look and you are looking down.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-05-2007, 08:00 PM   #7
piecesparts
Try these on for size. As you can see, no holes in the dash.
Old 01-05-2007, 08:01 PM   #8
piecesparts
One more from the front.
Old 01-05-2007, 08:04 PM   #9
82c10
needin' money
i know you said not to, but
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 01-05-2007, 10:40 PM   #10
84 400
Sb 400 club
84 400's Avatar
ahhh shift lights! ah just kidding guys. i got the sunproe 3 inch tach but i tried the hoes clamp and no dice! it interferesas with the tilt function. I will probibly drill the dash and mount it near were peice parts did when i mount it. Iknow drill the dash???? Well mine is a aftermarket pos so it is not really that big of a loss. I would aso sugjest maybe a piller tach with a trans temp and somthing else. munting below the radio i think is foolish cause you have to look down to see it
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-05-2007, 11:28 PM   #11
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
i mounted mine to the column at the closest to the dash with a column shifter, but i set it so that in the d/od position it was straight up and between the fuel and speedo. in p it was way off center and tilted funny.
trkklr77 is offline   Reply With Quote
Old 01-05-2007, 11:39 PM   #12
grinch4om
dang its hot
grinch4om's Avatar
like 82c10, mine is in that position but I used a mirror mount on the windshied and fabbed a mount to the monster tach body. the truck is apart now so I don't have a pic
grinch4om is offline   Reply With Quote
Old 01-06-2007, 12:53 PM   #13
wedgemon
wedgemon's Avatar
I put mine here...
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 01-06-2007, 08:00 PM   #14
magnethead
7000 #'s of american IRON
magnethead's Avatar
I've got a 3" on my column with a hose clamp, in first it blocks the left signal and part of the shift indicator, in drive it just barely lets me see the signal. In park it's about horizontal.
magnethead is offline   Reply With Quote
Old 01-07-2007, 08:20 PM   #15
75sierraclassic
Thanks for all your input, I ended up putting it on the upper part of the column that doesn't rotate with the gear selector. I had to take out the tilt lever, but I never need to adjust it anyway and nobody else drives it. I attached some picture of the install. I didn't tuck away the wiring very well but it looks ok. A big hose clamp and a little electrical tape and it doesn't look to bad.
Old 01-07-2007, 08:32 PM   #16
magnethead
magnethead's Avatar
Is that a replacement dash face? I don't think it is (as I think i see a washer in that very special spot), but if it is, where did you get it?
tach looks good.
Old 01-07-2007, 08:37 PM   #17
magnethead
magnethead's Avatar
That looks just like my friend's setup (5" monster with shift light and memory). His is a pearl blue 82 with 468 BBC and TH350.
Old 01-08-2007, 09:37 AM   #18
75sierraclassic
tach looks good.
Nope, the dash is all stock except for the dash cover and radio.
Thanks!
Old 01-08-2007, 09:38 PM   #19
magnethead
magnethead's Avatar
Thanks!
That's a nice looking face for that old then!!
mine's all faded, that upper left corner is completely gone, so i'm looking for a new or NOS one..junkyards come up empty, all the sierra classics have the sheetmetal faces that i find.
Old 08-21-2009, 02:51 PM   #20
Cubman
Thanks for the idea, grinch4om. After I read this I decided to buy a new rear view mirror and use the old one to mount the tach. My K10 is a Custom Deluxe, so no trim to screw the mount to. What is a conservative red line for my 400 sb? I set it to 4500 rpm for now.
Cubman is offline   Reply With Quote
Old 08-21-2009, 03:07 PM   #21
cadpwrd
cadpwrd's Avatar
Here is where I had mine on my 91 burb. I made a panel with some "el cheapo" home depot diamond plate plastic I had laying around. I'll probably get a 5" tach for my 86 when I get closer to finishing it.
cadpwrd is offline   Reply With Quote
Old 08-22-2009, 09:30 AM   #22
68 TT
Still plays with trucks
68 TT's Avatar
Mine is mounted from the pillar post like this as well.
68 TT is offline   Reply With Quote
Old 08-22-2009, 09:38 AM   #23
68 TT
68 TT's Avatar
Your stock cam probably runs out of steam right about 4500 so that is most likely the best shift point for you.
If you have a bigger than stock cam keep a stock 400 bottom end below 5500 rpm and you will be OK. The short rods are the weak link. With a 5.7" rod or 6.0" rod upgrade it can spin just like any other small block.
Old 08-22-2009, 10:20 AM   #24
3r!c84
Badass
3r!c84's Avatar
here yea go
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-22-2009, 10:21 AM   #25
asphaltburner
asphaltburner's Avatar
Yo! I gave up after being unable to find a functional, asthetically pleasing installation. I had considered ALL these possibilities, but I think I'll repeat what I did in my '76 Camaro,...replace the HUGE gas gauge with a tach, and install a small gas gauge in the clock option position with the small gauges.
Sure would like to have it displayed in the windshield glass just in front of the steering wheel. Hummmmmm,...
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
