Old 01-05-2007, 02:54 PM   #1
manimal
manimal's Avatar
Door striker ripping from jam?!
Has anybody had trouble with door strikers ripping the sheet metal from the door jam? Can this just be welded and doors aligned properly to fix the problem? BTW its a 1976 K20.Thanks
-Lance
manimal is offline   Reply With Quote
Old 01-05-2007, 04:10 PM   #2
SanitysBane
Re: Door striker ripping from jam?!
Same thing happend to our 88 Chevy Van. Its just a parts runner for when the truck is down, so I never really bothered with it.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 01-05-2007, 08:17 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Yep. I just had to repair one side on my 75 K5. I'd take a look at your hinges as mine were shot. That required a mule kick to get the door to shut and latch. It was bad enough that the striker actually got bent in towords the interior on one side, while the other side had 6 good cracks coming from it.
I replaced all the hinge pins and bushings and adjusted the doors to shut nice. My buddy broke out the mig and carefully stitched up the cracks on the one side. we did not remove the pin though. We were afraid the captured nut it is screwed into was loose and would fall into the body cavity. So we had to work around it with it as loose as we felt comfortable with. I didn't even take a grinder to the welds. just repainted it white. It's not pretty, but the area is solid again and the doors shut like new.
If someone had more time, you can fix the cracks and grind the welds down and put a proper coat of paint on the jamb.
Edit----
While you are there, you might want to look at the hinge mounting surface on the door too. Mine had cracks on both doors in this area. Pretty common too. We welded those cracks up too.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-05-2007, 08:31 PM   #4
manimal
manimal's Avatar
Cool Thanks Guys!
-Lance
Old 01-05-2007, 09:10 PM   #5
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
having this same problem with my blazer....at least i was when i was home last
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 01-05-2007, 10:44 PM   #6
joeymarkgraf
joeymarkgraf's Avatar
What can you adjust on doors? Just the striker or can you adjust the latching mechanism?
joeymarkgraf is offline   Reply With Quote
Old 01-06-2007, 05:11 PM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
You can adjust the striker pin on the jam a few millimeters in any direction. The rest of the adjustment is made at the hinges where they bolt to the body. The passenger side door on mine came off at least 6 times to tweak/move the hinges. (dirtylarry is a pro at this and wouldn't stop until it shut right) My driver side door only took a couple of trys.
My advice, replace the pins and bushings in the hinges first before trying to adjust. Mine were wiped out. No amount of adjustment would make up for the slop they had. For about $20 at Autozone in the "help" section you can get all the pin kits you need. Since the doors have to come off to replace the pins, you can get started on the adjustments once the pins are replaced.
Rob Z.
