01-06-2007, 05:06 PM | #1 |
Sway bar mounting ?
I just bought a front sway bar off a 1980 3/4 ton pickup. My question is, is it okay to mount the bar directly to the frame and not use the brackets for more ground clearance?
01-06-2007, 05:16 PM | #2 |
WTB this ad
Re: Sway bar mounting ?
I've seen it done that way. I don't see a reason it wouldn't work.
01-06-2007, 05:47 PM | #3 |
kyull76,
Do you plan on taking pics with your install? I'll have mine coming soon from Brothers Truck and it might help me with my install. |
01-06-2007, 05:58 PM | #4 |
Yeah I'll post pictures, but if you look in the faq truck tech section there's a really good write up with pics in there.
01-06-2007, 11:33 PM | #5 |
Out of the carpool lane.
My truck is lowered 4" in front and it fits better bolted directly to the frame. I've had mine like this for 6 years or more and no problems doing it that way. On a stock height truck I think you'll find it fits better using the brackets.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
01-07-2007, 11:05 AM | #6 |
General rule of thumb for mounting swaybars is you want the arms parallel to the ground.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
01-07-2007, 01:36 PM | #7 |
Thanks guys.
01-07-2007, 09:27 PM | #8 |
Cowboy Fan for Life!!!!!!
You can also switch it up and mount the sway bar on the "inside" of the front brackets. I've seen a post where someone did this, I'll see if I can find a pic. I think that will give you the "parallel to the ground" mount that you want...........Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
01-07-2007, 10:49 PM | #9 | |
Thanks. |
02-05-2007, 10:49 PM | #10 |
Any one have pics? I have a 1 1/4" bar off an 84 chevy and want to make sure I mount it correctly!
Where can I buy brackets if I need them, or is a junkyard the best place to find them?
1968 c10 Chevy 2005 Infiniti G35 2006 Subaru WRX STi |
02-06-2007, 02:30 AM | #11 |
A guy with a truck
If you are mounting to the frame AND bagged, you will run into interference problems with the pitman arm and drag link. I had to use 'lowered' style brackets for clearance.
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-06-2007, 02:36 AM | #12 | |
Lowered $19 Stock $49
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
