01-09-2007, 03:39 AM | #1 |
do i need a new mastercylinder?
I am about to order my disc brake/drop spindle kit from gmc pauls most likely and do i need to get a new master cylinder or can i use a proportioning valve. thanks everyone
01-09-2007, 03:47 AM | #2 |
Re: do i need a new mastercylinder?
if you currently have a drum/drum then youll need a new prop valve IIRC..
if you dont already have power brakes you can get the whole setup (pedal rod,bracket,booster,MC,propvalve)on the cheap out of a 73+ truck... something to ponder
-1947 3100 -1968 C10 -1970 K20 |
01-09-2007, 05:37 AM | #3 |
its all about the +6 inches
you'll need BOTH a new master, and prop valve in order to do it properly
01-09-2007, 11:05 AM | #4 |
thanks for the rply. also is the brake booster for my truckk fine. i have drum/drum
