Old 01-10-2007, 11:14 PM   #1
55dude
55dude's Avatar
Talking 70' 3/4 ton to 5-lug disc brakes
i have seen the info on 6-lug conversion but need to know if anyone has info for changing 1970 3/4 ton 8 lug drum to 5 lug disc's using factory parts. is 67-70 3/4 ton suspension the same. i have a 58' apache flatbed that has had the frame changed and apears to be a 67-70' 3/4 ton frame. if 5-lug can't be done i will settle for 6-lug thanks
55dude is offline   Reply With Quote
Old 01-11-2007, 12:11 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 70' 3/4 ton to 5-lug disc brakes
Cheapest way would be to swap out the front crossmember and differential with springs from a 73-86 1/2 ton. That gives you 5 bolt, discs up front, better gearing and a smoother ride.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
