Old 01-13-2007, 01:31 AM   #401
babyblueoval
babyblueoval's Avatar
Re: Dropmember in a 69 C10
Nathan,
I'd like to know more about the back-half.
Got any pics of the prototype you could post?
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 01-13-2007, 05:11 AM   #402
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Originally Posted by porterbuilt View Post
It would work out best if you just removed that crossmember and purchased a tubular trans crossmember to use. Besides, my guess is that you'll end up cutting it apart to get it out! (unless of course your truck is already completely dis-assembled). The structural integrity will not be compromised enough to make it 'unsafe'.
I was wondering if the frame would tweak especialy on a lwb frame but this is my plan on making a crossmember.
hope the pics come out!!!!!
shaneo2112RUSH is offline   Reply With Quote
Old 01-13-2007, 07:52 AM   #403
watahyahknow
watahyahknow's Avatar
http://stupid.comedyclips.nl/english...ip=432&soort=0
come to holland we got cloning down to a T
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-13-2007, 09:17 AM   #404
OldSarge
OldSarge's Avatar
I just want to lower my 69 C10 a few inches, not drop or slam it. What is the easiest and least expensive way to do it? Will changing the springs and shocks lower it?
Old Sarge is still kicking!!!
OldSarge is offline   Reply With Quote
Old 01-13-2007, 10:06 AM   #405
klownkar
Junior Member
klownkar's Avatar
Sarge, the first time that I lowered mine I did just springs, 3" drop. It owrks but you ride will suffer in my opinion. I changed it all a few years down the road and put a 2" spindle and a one inch spring and it help the ride but you can go either way
klownkar is offline   Reply With Quote
Old 01-13-2007, 10:27 AM   #406
Rokcrln
Rokcrln's Avatar
Yes you can just change out your springs and shocks but that will afect your ride, handling and steering just a bit because of the change in cast and camber but most guys have started out that way at some point and time. For the front end that would run you about $150 give or take. The rear I would just do springs as it will not affect much if you are only wanting a few inches.
What most guys end up goint to in the front would be like discribed above are 2.5" drop spindles $229 (ECE) and 1 or 2" lower springs $110+- (ECE) then shocks. So since most of us end up going this way in the end why not learn from us and jusat do it to start with! It involves almost the same amount of work since you have to half way undo your stock spindle to change out a spring anyways. Good luck and I hope you like what ever way you go.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-13-2007, 07:49 PM   #407
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by babyblueoval View Post
Nathan,
Pics of the prototype should be surfacing in the near future... I beleive the customer will be posting his build on this site....
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-13-2007, 08:07 PM   #408
XXL
Seņor Member
XXL's Avatar
In the mean time, here's a pic of a bike frame prototype PB has been working on
</i keed, I keed>
XXL is offline   Reply With Quote
Old 01-13-2007, 08:46 PM   #409
Hart_Rod
Hart_Rod's Avatar
</i keed, I keed>
An A for effort. A D- for execution!!!!!
Hart_Rod is offline   Reply With Quote
Old 01-13-2007, 09:44 PM   #410
kyle4381
Is that a Softail or a rigid chopper?
kyle4381 is offline   Reply With Quote
Old 01-13-2007, 09:55 PM   #411
babyblueoval
That would have to be semi-rigid.
The frame material was obviously specially selected so it would absorb the harmonics of the road and flex with any harsh surface imperfections.
Man that is some smart thinking!!
Jim
Old 01-13-2007, 10:09 PM   #412
PBFAB.COM
PBFAB.COM's Avatar
I had to go to a pine... the balsa proved to be too fragile. I thought all evidence of that build had been destroyed!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-15-2007, 07:39 PM   #413
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Nathan, great to talk to you today. I will be in touch with you soon about getting mine ordered. One question I forgot to ask you: I'm running a 2-piece drive shaft, even w/ that will one piece still have to be lengthened? And if so, I guess it would be the front half? Also, if the motor is moved, what does that do to core support and fan shroud tolerances?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-15-2007, 10:27 PM   #414
PBFAB.COM
PBFAB.COM's Avatar
I think you will be "pioneering" the two-piece drive-shaft and Dropmember combo. I am assuming the front shaft will need to be lengthened, and the carrier may need to be shimmed???... I don't know which trailing arm crossmember you're running.
The core support does not need to be moved (I am unsure why moving the 'radiator placement' was referenced in the Classic Truck's article... The radiator and core support are un-touched and un-altered. The shroud may need to be modified... I know a stock shroud will have interefrence issues with the fan after the install.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-16-2007, 01:36 PM   #415
67Fleet
67Fleet's Avatar
I'm running the stock crossmember but will be going to the ECE drop crossmember for clearance reasons. For 200 bucks it's worth it for me just to buy theirs than spend my time modifying my existing one.
Not sure why the carrier bearing assembly would need to be shimmed. Can you elaborate?
-Bret
Old 01-16-2007, 02:21 PM   #416
PBFAB.COM
PBFAB.COM's Avatar
For pinion angles... The trans will be moving upward, thus changing the pinion angle, if the carrier is left at the same height. There are great references to information about pinion angle that SlammedDime has posted in other threads. It should help you in finalizing your pinion angles.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2007, 05:19 PM   #417
blazntn
I have a question before I start installing my dropmember. What do you do with the lines that run in the back of the original? They have a bunch of crazy bends. Just curious what everyone else has done!! Hey Nathan hit me up sometime!!
Brad
www.gaugemagazine.com
blazntn is offline   Reply With Quote
Old 02-04-2007, 03:36 PM   #418
Kenneth_CS87
Im running a Late model Lt1 engine in my truck, would this setup have any effect on the pulley setup? Im not running any AC Just a AC delet.
Kenneth_CS87 is offline   Reply With Quote
Old 02-04-2007, 11:47 PM   #419
SCOTI
SCOTI's Avatar
There's no mention of who this 'customer' is . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2007, 02:08 AM   #420
64shortc10
64shortc10's Avatar
Kenneth_CS87,
Hi, Im running a Porterbuilt dropmember in my 64. I am also running a 94 Trans Am LT1. I still have the A/C in the stock location so I beleive this combo will work for you also. I totally recomend the dropmember, it looks so much cleaner then a cut up Z notch. Good luck!
Nathan,
Still awaiting my rack notches and rack to spindle Heims. Any word on there where abouts? Also still intrested in a price on those hood hinges, and a polished power rack like the one installed on dino's 66? I'm not being pushy,
I'm just excited to finally start purchasing some higher dollar parts.
Thanks again.
Tony from Norcal.
64shortc10 is offline   Reply With Quote
Old 02-06-2007, 12:14 AM   #421
PBFAB.COM
PBFAB.COM's Avatar
This 'customer' will surely be posting pics along the way... I too will be posting pics of the piece, when completed. He is from Texas.
By the way... finally have your manual rack/DropmemberC4 dillema resolved. I am awaiting for a price on the rack and will be letting you know.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-08-2007, 11:42 PM   #422
PBFAB.COM
PBFAB.COM's Avatar
OK... this has nothing to do with the Dropmember, but there had been a few requests to see more of this car as it progressed...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-08-2007, 11:50 PM   #423
Shane
Shane's Avatar
No offense, but what is that "thing" over the rear seat area ... reminds me of a Porsche 914.
Shane is offline   Reply With Quote
Old 02-09-2007, 12:24 AM   #424
SCOTI
SCOTI's Avatar
This 'customer'...... is from Texas.
Let me know the details when you have them . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-09-2007, 11:50 AM   #425
jlaird
jlaird's Avatar
Is that car on bags? If not, I personally think the wheels look too big. They need to be tucked more. IMO
That engine looks sick!
jlaird is offline   Reply With Quote
