Old 01-14-2007, 01:42 AM   #1
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
calipers and brake hoses
Any know of an aftermarket kit for the calipers and hoses which fit the light duty rotors (1" diameter) If anyone can point me in the right direction I would appreciate it. thanks!
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 01-14-2007, 08:34 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: calipers and brake hoses
Aftermarket as upgraded parts or aftermarket replacement parts? OEM rubber hose or braided steel hoses? I'm sure there is some kind of better caliper but not sure what all you will run into to get the installed. Like if you need brackets, different or modified spindle things like that.
I might be able to get some part numbers if I know what year/model/engine vin number or stock engine size it came with.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-14-2007, 09:19 PM   #3
AspecialZ
AspecialZ's Avatar
It was a ground up restoration, I went from HD rotors to 1" rotors. Im sure stock would work, but I can't find them. I even tried calling a custom company that would make them for me, theu can't help.
Old 01-14-2007, 09:44 PM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
A..Z-
You should be able to get the 'aftermarket' calipers and hoses at the local chain Auto store. If you're looking to step up, check out Classic Performance Products. They have a front disc kit for the 62-87 trucks. But, I think that use 12" rotors.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
