01-14-2007, 12:05 PM | #1 |
67 hood on 71?
has anyone tried to make a 67/8 hood fit a 71 style front end? Anyone have pics?
01-14-2007, 12:38 PM | #2 |
Re: 67 hood on 71?
you need 67/68 fenders and grill too. im not shure about the core support.
01-14-2007, 02:10 PM | #3 |
Re: 67 hood on 71?
changing the leading edge of the hood is what is needed but wondering if anyone has doon it yet
01-14-2007, 02:23 PM | #4 |
Re: 67 hood on 71?
You will need the 67-68 core support, fenders and hood to complete the transformation.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
01-14-2007, 03:41 PM | #5 |
I am a Referee of life.
Re: 67 hood on 71?
The hoods are a different length.I have seen a 71 with the hood pie cut and leaned back like the 67-68 hoods.It looked good and was something only someone who knew would notice.If it looks like the factory did it that way it's usually a goood modIMHO.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-14-2007, 05:40 PM | #6 |
Re: 67 hood on 71?
Buffalo is right, basicly you need the entire front clip!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
01-14-2007, 06:10 PM | #7 |
LAIDOUT
Re: 67 hood on 71?
Are you referring to this look? Its not my truck, just a picture from my collection. I thought about doing it until I located an early front clip.
01-15-2007, 09:47 AM | #8 |
Re: 67 hood on 71?
thanx for the pic. that is exactly what i want to do to my truck, i will be trying the hood swap this week, pics to come!
01-15-2007, 11:00 AM | #9 |
Re: 67 hood on 71?
take your 69-72 hood and lay it back, one site to look at is if customs the have done this many times and have alot of pictures of this being done, take a look at matt eye's section on there site. hope this helps
01-15-2007, 11:13 AM | #10 |
Re: 67 hood on 71?
I think what cooters was asking is a trick that most people would not due because of the amount of work involved. It involves taking a 67-68 hood and shorting the leading edge to the length of a 69-72 and it can and has been done. Their was a burb that had this mod and it looked nice but so does doing the pie section to a 69-72. The only thing with doing a pie section is people that know what they are looking at can see that it is the corect hood just tweaked abit. As with the 67-68 hood on a 69-72 front end should not be able to fit at all so people are not quite sure what took place. Even when you lay the front of a 69-72 back to the same slope as a 67-68 their is still alot of differances between the two. Look at the distance from the front side edge of the hood to where the body line curves up to the upper front slope and you will see the differance between the two hoods. A 67-68 has a longer "ramp" than a 69-72. Yes the core supports are different but only in the head light mounting area and the hood latch. With a few simple mods you can take a 69-72 core support and remove the head light bucket and use that support on a 67-72. But to use a 67-68 on a 69-72 you must fins these head light buckets and weld them on. Keep in mind that chevy was cheap and wanted to use the same basic part for as long as they could and this is good for all of us. Hope this all makes sence!
Kevin LFD Inc. |
01-15-2007, 11:19 AM | #11 |
Re: 67 hood on 71?
Can you document the cutting and welding process? I'd like to see the outcome.
01-15-2007, 11:30 AM | #12 |
Re: 67 hood on 71?
For those that have not noticed the side differance between the two styles here is a white 67 and a brown 70 to compair. I may have to do the 67 hood on my 70 for my "Low buck truck build" thread it would be fun
Kevin LFD Inc. Last edited by Rokcrln; 01-15-2007 at 11:33 AM. |
01-15-2007, 12:53 PM | #13 |
Re: 67 hood on 71?
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
01-15-2007, 01:26 PM | #14 |
Re: 67 hood on 71?
Yeh this is the one I was thinking of. I was out looking at some of the hoods that I have and it would not be all that bad depending on how you went about it. Problem is what looks like the easy way to put a 67-8 hood on a 69+ will take two hoods (one of each) but that is not a big deal if you have several laying around right
Kevin LFD Inc. |
03-05-2007, 06:45 AM | #15 |
Re: 67 hood on 71?
I asked about the hood in another thread but this brings up a new question...
Other than the marker lights, is there any real difference between the early and later fenders? ----EDIT--- Nevermind, I see can the difference now in post #12
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 03-05-2007 at 06:48 AM. |
03-05-2007, 09:17 AM | #16 |
Re: 67 hood on 71?
It`s simple to do this on a GMC.Bolt a 67-68 hood on your 69/72 and eliminate the brows and top bar...done.
03-05-2007, 09:47 AM | #17 |
Re: 67 hood on 71?
ive been trying to get started on the swap but here is first step, however it will be for a chev grill not a gmc
03-05-2007, 09:54 AM | #18 |
Re: 67 hood on 71?
This has really got me thinking. I realize the fenders on the 71 GMC are the same as 67-68's, but the hood is like the 69-72 Chevy's, where does the transition take place.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
03-05-2007, 10:21 AM | #19 |
Re: 67 hood on 71?
There was an issue of Classic Trucks where they showed the entire process of removing the front brace on a 69-72 Chevy hood. Then they pie cut two inches around the front of the hood. Then they tampered the cut on the sides of the hood. Meaning pie cut all they way back,,, almost to about four inches from the back of the hood. What they did is made a 69-72 hood look like a 67-68 hood.
...try'n to be a little! This is a great site. http://67-72chevytrucks.com/vboard/s...d.php?t=157669 http://www.67-72chevytrucks.com/vboa...d.php?t=375640 |
03-05-2007, 10:53 AM | #20 |
Re: 67 hood on 71?
In`69 when the hoods changed,GMC added the eyebrow trim to the fender front edgeds and riveted a surround piece (top bar) to the top of the grille to fill the gap.The `68-70 grilles are the same,other than the top bar on the 69/70s.You could swap any year GMC grille around between 67-72.The only thing that seperates the`67 from the 68/70 grilles is the`67 has GMC stamped in it.
03-05-2007, 06:08 PM | #21 | |
Re: 67 hood on 71?
Rg
03-05-2007, 06:41 PM | #22 |
The LuvShack Garage
Re: 67 hood on 71?
03-05-2007, 07:41 PM | #23 |
Re: 67 hood on 71?
well as soon as i get some time, i will cut 1 1/2 inches from the front of the hood and weld in a front edge and it should be done. There is nothing a weekend of welding and cutting cant cure
03-05-2007, 11:11 PM | #24 | |
Re: 67 hood on 71?
03-06-2007, 12:42 AM | #25 |
Re: 67 hood on 71?
The`67s didn`t have a top bar or surround trim.I know that.The rest is true.I was just answering how this could work with the gap compared to a Chevy.Not the entire swap,good info.
