11-11-2002, 10:37 PM | #1 |
new master cylinder
i replaced my leaking non power master cylinder on my 69 with a new master cylinder. i did as the instructions said and pumped fluid through the cylinder by hand then hooked up the lines and put it back in and now i press the pedal down, the fluid in the resoirvoir doesnt go down, and when the pedal gets down it stays down?? what do i do? i quit for today, and am going to fix it tomorrow, just thought id get some advice and whatnot before, maybe somebody here can help me get it fixed quicker than i could alone. thanks, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
11-11-2002, 11:50 PM | #2 |
its all about the +6 inches
When the pedal stayed down on the one ton...it was a kerfagled booster.
11-11-2002, 11:57 PM | #3 |
Can you manually pull the pedal back up?
There's a spring inside the master cylinder that pushes the assembly back out. If the spring is missing or broken, or the pedal/linkage is binding... your pedal will stay down. When bleeding brakes, your resevior wont go down until your pedal comes up. This is when the cylinders replenish with fliud from the resevior. If the M/C felt ok and would return ok on the bench, chances are the spring is ok. Double check your linkage/pedal. Also, are you getting a good flow of fluid from the lines where they connect to the M/C? This should be the first place you start to bleed after a M/C replacement. Then begin at the furthest wheel from the M/C and work your way in. Reason being, if there is air trapped at the MC, you dont want to try and pump that all the way through your system. |
