Old 01-15-2007, 06:50 PM   #1
Billla
Billla's Avatar
FlowTech Headers anyone?
I just gave up and bought a set of these, painted for $105 @ Summit. I usually don't lowball on headers (I paid $1700 for my Impala SS headers!) but I'm in the process of "downgrading" my '72 into much more of a daily driver from my original lofty performance goals. When I build the new chassis I'll spring for a set of tri-y's and a nice system - this is to keep me going for the next 3-4 years.
Anyone installed these? They look about right, and the flange is nice and thick. The tube size is a bit small but that should be fine for what I'm looking for. Looking for personal, direct experience.
Thanks!
Billla is offline   Reply With Quote
Old 01-15-2007, 06:59 PM   #2
cstm68
cstm68's Avatar
Re: FlowTech Headers anyone?
are they full length or block huggers ??
i used the flowtech full length ones on my 68 and thy fit good i had to remove the oil fiter and the starter to install them!
cstm68 is offline   Reply With Quote
Old 01-15-2007, 07:13 PM   #3
mac
Active Member
mac's Avatar
I just took a set of alumi coated Flowtechs off and replaced them with Hedman Ceramic longtubes. I liked 'em fine and had no trouble with the angled plugs on my ZZ4 either. On lowered springs I could drag 'em but they held up fine to a lot of speed bumps and bad angled driveways.
mac is offline   Reply With Quote
Old 01-15-2007, 07:17 PM   #4
Boise69
The Hammer Man
Boise69's Avatar
a little off subject but i have flowtech mufflers, installed 4 years ago and both are now rusted through and i need to replace. just thought i'd share.
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 01-15-2007, 07:23 PM   #5
Billla
Billla's Avatar
Full-length. The install instructions say that both of these must be removed...so sounds good so far
Old 01-15-2007, 07:24 PM   #6
Billla
Billla's Avatar
Yeah, painted headers typically look like rusted garbage in a year or so. I can live with that for $100
Old 01-15-2007, 07:50 PM   #7
notmrgoodwrench
i have a set of these on my 67 and so far so good
notmrgoodwrench is offline   Reply With Quote
Old 01-15-2007, 08:00 PM   #8
jsbgump
Gone Fishing
jsbgump's Avatar
I've had a set on the 68 for almost 9 years. they were ok at first but the collectors warped on me and they look like crap now but hey they work for the price
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-16-2007, 12:40 AM   #9
chopper103in
chopper103in's Avatar
got them on my 69 swb and i like them
chopper103in is offline   Reply With Quote
Old 01-16-2007, 12:41 AM   #10
skokie
skokie's Avatar
I had a set of full length and they lasted 18 months.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-16-2007, 01:52 AM   #11
71chevytruckguy
71chevytruckguy's Avatar
i got on my '69 and no problems. if your goin in fron the top, take the plugs out, remove the strater, and the brake booster can keep the master cylinder hangin out the lines, and they should drop in. also remove the z-bar and clutch linkage if its manual. only problem i've had with them is gettin the reducer to collector gasket to seal up. used 2 paper gaskets per side and haven't had a problem. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 01-16-2007, 01:59 AM   #12
Blue85
Oilfield Trash
Blue85's Avatar
i have a set on my truck, no problems so far, but i only put about 1000miles on y truck so far. I never had to remove anthing to get the headers in, driver side was a tight fit though. Makes me wonder if my engine mounts are in the right spot.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 01-16-2007, 02:16 AM   #13
chopper103in
i had to replace both motor mounts to get my headers to fit-----rubber in both mounts collapsed
Old 01-16-2007, 09:57 AM   #14
Billla
Billla's Avatar
These were the full-length FlowTechs?
Old 01-16-2007, 10:45 AM   #15
chopper103in
yes---rubber collapsed and the motor sat to low and the headers hit crossmember so the bolt holes wouldnt line up-----tha mounts was basicly metal to metal
Old 01-16-2007, 11:06 AM   #16
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Mine were pretty easy to installing seeing that I didn't have a body on the frame. Haven't fired up the truck yet so don't know how they hold up yet.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 01-16-2007, 11:59 AM   #17
Billla
Billla's Avatar
Good heads-up; I've got brand new mounts on mine...well, 7 year old brand new so they should be good.
Old 01-19-2007, 01:47 PM   #18
Billla
Billla's Avatar
These arrived yesterday and I was underwhelmed. I think I'm going to go ahead and install them...but I was not real happy with the "quality". I know it's a lowball header, but I was surprised at the really poor welds and what looks like flanges that are ground on a bias. I'll post some pictures along with the installation, but out of the box I was not rocked.
Based on what I saw, I wish I had spent the extra $30-$75 on the painted Headman or Hooker Competition headers and that would be my recommendation - and of course the good thing as well is if you upgrade to coated headers they (should) bolt right up.
Old 01-19-2007, 02:47 PM   #19
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i got flowtech on my blower motor and they work real good i also read in hot rod mag that they did a headers test and these flowtechs were rated right up with heddmen and other for the overall performance
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-19-2007, 03:17 PM   #20
bryanw1968
bryanw1968's Avatar
I bought a set of full length flowtechs for my '68 and they worked just fine for the money. I eventually upgraded my entire exhaust system just as you're talking about doing with some hedman elites.
bryanw1968 is offline   Reply With Quote
Old 01-19-2007, 05:41 PM   #21
centsless
sufficiently talented fool
centsless's Avatar
I put them on mine, and the flanges do not have a gasket at all. No leaks, and they fit pretty well. My truck sits in the garage, and we put 500 miles on it this year, so it is not used a lot. I like them and would buy another set. My SS Impala now has a crack in the exhaust manifold, so I am going to join you and shell out big bucks for some LT1 headers.....
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 01-20-2007, 12:17 AM   #22
Premium72
Premium72's Avatar
had mine for about 4 years now. no problems. lil deeper sound. didnt have to take any tihng off to intsall. i installed from under the truckk(truck jaked up...rite in. i like em. like you say cant beat the price.
Premium72 is offline   Reply With Quote
Old 02-04-2007, 07:25 PM   #23
Billla
Billla's Avatar
[UPDATED]FOLLOW-UP
Finally had time today to start the install on these. They have MAJOR interference on the motor mount on the passenger side. I wouldn't mind clearancing a bit...but it would have to be maybe 1/4" and I'm not doing that. Moving to some Hookers, which is what I should have bought in the first place.
You can see from the pictures I posted in the thread below the difference between the two headers. I guess the determining factor is how far forward your mounts are.
http://67-72chevytrucks.com/vboard/s...13#post2017213
Old 02-04-2007, 11:26 PM   #24
FLEET72
FLEET72's Avatar
10 year old Hookers. I bought them from the Super Shops for $60 when they were clearing out stock right before the locked their doors for the last time.
Passenger side, hard to tell from the picture but there is at least 2" of clearance to the motor mount.
A little further back, Dang autofocus.
Driver side, also at least 2" of clearance.
Again, further back.
Pictures are dark because I took them at night.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
Last edited by FLEET72; 02-05-2007 at 05:04 AM. Reason: Fixed pictures, changed to links, hope that works. - Picasa -
FLEET72 is offline   Reply With Quote
Old 02-05-2007, 01:07 AM   #25
krue
Designated A-hole!
krue's Avatar
Nothing but red x's showing for me fleet72.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
