Old 01-17-2007, 11:40 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Making preparations to pull motor.
I decided to pull the motor on my 71 to replace the pan gasket (pan is loose, but can’t get it out). I will need to jack up the block to get the pan off which requires the mounts to be undone anyway….the motor mounts need changing too.
So I would like a list of do’s and don’ts and any tricks to help me out. I never pulled a American engine before so not too sure what to do.
Thanks,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-17-2007, 11:57 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Making preparations to pull motor.
drain antifreeze
pull radiator
remove fan assy
disconnect all hoses
disconnect battery
remove carb linkage
remove carb... install lift plate
disconnect all wiring hei, starter, etc
disconnect alt bracket and swing to the left lower inner fender
remove bellhousing bolts
remove flex plate bolts
slide converter all the way back inside trans.
support trans with jack
remove engine mount bolts
connect lift to lift plate on intake [ pull it out]
rage'nrat638 is offline   Reply With Quote
Old 01-18-2007, 01:38 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
digi photos will help on the vac lines, and bracket locations... or poor art work (drawings) will do if there's no digi cam.
Mark, you forgot to pull the hood!
fan shroud needs to come off if you still have it
Disconnect the fuel line at the fuel pump, the frame side of the line.
If you don't have a carb lift plate, then no need to buy one. They are nice, but not needed.
If you have power steering, unbolt it from the engine, and flop it over on the frame... same for a/c stuff
If the engine is original and unmolested, then there are ground straps on the valve covers to firewall, unbolt them
take your time, tripple check everything. Lift the motor a few inches, then look at everything again.
Old 01-18-2007, 03:27 AM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Run and gun!
Take no prisoners!
No pain, no gain!
Don't take no for an answer!
Don't shoot till you see the whites of their eyes, and
Aim for the heart...sometimes they charge when they're wounded!
Oh yeah...righty tighty, lefty loosey.
Keep your cell phone handy and programmed for 911!
If you buddies come over to help...DON'T let them drink!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-18-2007, 03:30 AM   #5
ghetto_superman
ghetto_superman's Avatar
ENGINE HOIST: a tool for testing the tensile strength of everything you forgot to unhook.
good luck!!
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-18-2007, 03:41 AM   #6
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
A good point is to mark the hood and hood hinges where they line up so for when you reinstall you dont have to mess around with alignment.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 01-18-2007, 08:48 AM   #7
Imacarguytoo
Disconnect your headers or your exhaust manifolds also.
Imacarguytoo is offline   Reply With Quote
Old 01-18-2007, 09:44 AM   #8
Ron 586
RIP Mr Ron
Ron 586's Avatar
How many members have their trucks scattered all over the garage that started out to tighten the fan belt. Take pictures, it might be the last time you see it in one piece.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 01-18-2007, 10:41 AM   #9
arkracing
Weekend Warrior
Shouldn't have to pull the hood if the radiator is out. Have a buddy/kid/wife "ush the hood a little further up with a broom handle or get a 2x4 to hold it up a little higher - there is a little more room these old hinges flex around alot.
Make sure that you get the motor hoise hook/chain as tight as possible to give you the most clearance.
I pulled a V8 out of my 4x4 without taking out the Radiator or Pulling the hood. Just have to know how to angle the motor around. These trucks have an airport under the hood. You can basically spin the motor around 360 in there.
Good Luck
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-18-2007, 10:06 PM   #10
roj2323
I’m doing this right now my engine goes back in tomorrow I edited rage's post to add stuff and change the order, as it's pretty important that it's done in a certain order. "Example: removing bell housing bolts before the flex plate bolts is dangerous to both you and the trans."
remove hood----- mark placement can be done without but it's a PITA.
Disconnect battery
Drain antifreeze
Remove fan and shroud
Pull radiator
Disconnect all hoses
Remove carb linkage
Remove kick down cable
Remove ground straps including negative battery cable to engine block
Disconnect wires to
-Distributor
-Alternator
-Oil pressure sensor
-Water temp sensor
-Choke
------Skip if you don't have A/C------
Remove trigger wire on compressor
Remove compressor-mounting bolts
DO NOT REMOVE HOSES
Remove any brackets holding hoses to engine and pull compressor with the hoses still attached to the side. Secure with a bunggy cord or wire coat hanger to keep it out of the way.
Remove starter
Remove tork converter cover
Remove flex plate bolts
Slide converter all the way back inside trans
Remove exhaust from manifolds
Remove bell-housing bolts
Support trans with jack
Connect engine lift to lift plate/chain on engine put enough pressure to take out the slack but not enough to lift engine <safety thing
Remove engine mount bolts
Lift engine [ pull it out]
ondrew
ps. i've done probably 20+ engine R&R's and SBC's are the easiest so don't worry about it.
roj2323 is offline   Reply With Quote
Old 01-18-2007, 10:09 PM   #11
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
HAHAHA! I took my motor out to rebuild it.
That turned into:
TH400 swap
Tubular mounts
Power brakes
Power Steering
68 Frontend swap
Wheels and tires
And guess what? Motor still isnt in the truck yet.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 01-18-2007, 10:48 PM   #12
paaw
paaw's Avatar
I'm leaving mine's in and just building one to replace it
paaw is offline   Reply With Quote
Old 01-18-2007, 10:52 PM   #13
1969k10stepside
I would get all the grease off it before I started taking stuff off,put on some degreaser and get all the grease off,powerwasher is helpfull
1969k10stepside is offline   Reply With Quote
Old 01-19-2007, 12:06 AM   #14
texanidiot25
Eat My Rust
texanidiot25's Avatar
good luck!!
Best tip ever.
texanidiot25 is offline   Reply With Quote
Old 01-19-2007, 11:59 PM   #15
Sport/Truck
Sierra Grande Club
Thanks everyone for all the good suggestions, I’ll have this list handy this weekend when I lift the motor out!
s/t
Old 01-20-2007, 07:37 AM   #16
kndall
kndall's Avatar
If you have a steel line for your oil pressure (as original) do not forget to unhook it. It will make a hell of a mess if you forget that one thing and don't unhook it.
I am a proud member of the "No, it's not for sale, I'm gonna fix it up someday" club.
kndall is offline   Reply With Quote
Old 01-20-2007, 12:25 PM   #17
53lowdown
Junior Member
53lowdown's Avatar
If you've pulled non-american engines before (i.e front drive imports?) This will be a breeze.
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 01-20-2007, 04:48 PM   #18
Sport/Truck
Sierra Grande Club
That’s what I’m say’n, the last motor I pulled was an AWD turbo 4g63 in a VR4 Galant.
This is looking good.
s/t
Old 01-20-2007, 05:00 PM   #19
Sport/Truck
Sierra Grande Club
I’m thinking of pulling my exhaust manifolds off and doing a test fit of the headers to double check fitment. If I pull my manifolds off, can they be reinstalled with out any issues?
s/t
Old 01-20-2007, 05:58 PM   #20
Longhorn Man
I like unbolting the manifolds, and leaving them on the pipes in the engine compartment. Makes dropping the engine in easier. Instead of worrying about the pipes goinf up in the right area surrounded by the studs, you just drop the engine in and worry about the motor mounts.
Old 01-20-2007, 07:27 PM   #21
Sport/Truck
Sierra Grande Club
Thanks, but I want to undo everything to test fit the headers anyway. Broke off one stud on the down pipe. I’m now starting to remove the manifolds. After the test fit the only thing is left is motor mounts then pull it out.
s/t
