Old 01-18-2007, 09:26 AM   #26
vern350
like a rock
vern350's Avatar
Re: 2wd to 4x4 build
why does the burb frame have more room for the diff to move? I guess i have to keep an eye out for 3/4 ton 4x4 p/u mounts and engine crossmember. Another option is to cut the burb frame back where it has the same height and same frame dimensons as the pickup frame and weld the front portion of the burb frame to the pickup frame. Friends of ours have made 2 or 3 of those 4door shortbox trucks.
vern350 is offline   Reply With Quote
Old 01-18-2007, 12:52 PM   #27
1lowdiesel
1lowdiesel's Avatar
why can't you use the whole burban front clip and just z the frame to make everything line up.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 01-18-2007, 12:58 PM   #28
Russell
Professional Grade
Russell's Avatar
I'd reccomend finding a donor 1/2 ton with a 350 to grab the engine crossmember, front crossmember, and engine mounts out of, easier, and less likely to have problems in the future than if you cut and weld the two frames together, unless you are a really good welder.
That, and when you go to insure the thing, the insurance company is going to drag your truck through the coals of a nasty inspection to try and find some excuse not to insure your rig. Thats my biggest battle now that most everything is basically done. My current company won't even consider insuring it, no matter what kind of safety inspection it passes.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-19-2007, 11:41 AM   #29
vern350
like a rock
vern350's Avatar
Most likely going to have the frame zed by our friends whos done multiple shortbox conversions. Saves having to grid or cut out all the rivits.
Old 01-19-2007, 12:47 PM   #30
cobinder
Everything is work in progress
cobinder's Avatar
You may have already seen this site. If not heres a link to chassis dimensions, RPO codes and VIN # info.
Lots of info, helped me out tons,
Good luck with your project.
http://www.chuckschevytruckpages.com/framespecs.html
http://www.chuckschevytruckpages.com/73-87specs.html
http://www.chuckschevytruckpages.com...s_1973-87.html
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 01-22-2007, 01:45 AM   #31
Russell
Professional Grade
Russell's Avatar
Any updates Vern? I'm starting my swap tommorow...
Old 01-22-2007, 08:38 AM   #32
vern350
like a rock
vern350's Avatar
not awhole lot, bought an 78 stepper yesterday. Probably going to cut off teh front end of the burb with enough room for play. Take the rear axles and rear hangers, and any necessary parts. Room is getting tough to come by now. What swap are you doing again? An 3/4ton 4x4 swap under a stepper?
Old 01-22-2007, 01:06 PM   #33
Russell
Professional Grade
Russell's Avatar
Actually, 1/2 ton swap under the stepper now, wound up buying a K5 to do the swap...
Eventually put the 3/4 ton stuff I found under the K5 after I get new spring hangers and stuff for it.
Old 01-24-2007, 02:30 AM   #34
Russell
Professional Grade
Russell's Avatar
Well, looks like its not gonna happen anymore. Outta the blue my buddy just straight up gave up on me, and I'm not gonna spend my time and money on a truck that I'll never use on my own....
I'd rather fix my quad, and have nearly unlimited access on crown land, with a big group of buddies I know well than to have a few hundred kilometers of trails to ride in a fullsize, with a group of people I barely know, and half the time don't even want to be associated with due to their serious alcohol and drug problems.
Yeah, I'm a little annoyed at the moment, I just dropped like 500 bucks on parts for all this, and now I have to try and sell all of it cause he is acting like a 13 year old kid who is afraid of a little elbow grease.
Old 01-24-2007, 09:54 PM   #35
vern350
like a rock
vern350's Avatar
bummer, were you going halves on the truck?
Old 01-24-2007, 11:42 PM   #36
Russell
Professional Grade
Russell's Avatar
yeah, we did... I'll have to buy out his half of the K5 then sell it.
The fortunate news is that I may have sold my 77... It'll go for between 1500 - 1700 as is, while I've got about 500 into it, lol Not quite done negotiating yet...
Old 02-26-2007, 04:15 PM   #37
vern350
like a rock
vern350's Avatar
getting the front 4x4 frame welded to the rear part of the 2wd pickup frame today. Pictures will be coming tonight. I have been busy with college and other activities, so hopefully things get back up to speed shortly.
Old 03-03-2007, 05:10 PM   #38
vern350
like a rock
vern350's Avatar
i've got the frame cleaned up, just wondering if I should paint it or leave it and have it oiled? I figure if i paint it and then 2 or 3 yrs later if it flakes, water/salt/dirt will be able to build up and rust. What do you think?
Old 03-06-2007, 07:00 PM   #39
vern350
like a rock
vern350's Avatar
I've got the frame painted now, along with the tranny and tcase cleaned up. Next steps are to run fuel lines, and finish the brake lines and then the motor and tranny/tcase will be dropped in. I'll be ordering a 4" lift with in the next couple of days. Any suggestions for a 4" lift?
Old 03-06-2007, 08:00 PM   #40
84 400
Sb 400 club
84 400's Avatar
Wow that looks nice. so you ended up putting the burban front frame on the pickup rear half?? Did you keep the rear pickup setup or swap that for the burban rear suspention
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-06-2007, 10:17 PM   #41
Russell
Professional Grade
Russell's Avatar
Do a shackle flip out back, and 4" springs up front
Old 03-07-2007, 12:06 AM   #42
vern350
like a rock
vern350's Avatar
its burb up front and pickup in the rear with burb axle. I saw a shackle flip somewhere, i'm going to look into it. It needs new springs in the front so, why not lift it? right?
Old 03-19-2007, 07:58 PM   #43
vern350
like a rock
vern350's Avatar
we'll i got the parts truck home. You may have seen it in the "what have you got done" thread already. Frame is a little weak in the middle, and the missing engine doesn't help.
Old 03-31-2007, 02:31 PM   #44
vern350
like a rock
vern350's Avatar
Motors in and new brakes are installed. Still debating what to do for a lift.
Old 04-11-2007, 05:28 PM   #45
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Gotten any more Done on the Project?
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 04-15-2007, 05:43 AM   #46
Slammed66
Needs a Big Block
Slammed66's Avatar
Russel
I have 2 SWB 4x4 frames I know of around here , with diffs and ! I can get the T case and drive shafts too... and some beater box sides.....
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 04-15-2007, 11:43 AM   #47
Russell
Professional Grade
Russell's Avatar
Now you tell me!
Just sold my stepside, lol
Old 04-15-2007, 01:44 PM   #48
vern350
like a rock
vern350's Avatar
not a whole lot as been happening. Been busy with school, as I have exams in 2 weeks. Got the cab off the shortbox truck and stripped. Its rougher than we want, so where going to look for something else. Not a loss, because the fenders are in excellent shape and i may be able to use the box. My old man and myself are toying of the idea of going down south for a truck or putting my dads 86 scotsdale on it.
Old 06-07-2007, 02:04 PM   #49
vern350
like a rock
vern350's Avatar
Re: 2wd to 4x4 build - New pictures
finally found a solid truck for a body, minus a cab. Was out for a drive one day and saw this 82 sitting in a driveway without plates, so i went a knocking and here she is. Has got 390,000 kms on it. Body was redone a few years back, southern box, doors, etc. Cab corners, rockers, and mounts are shot. The 350 still runs strong, has got full gauge cluster, 8" rallys to name a few bonus' of the truck. Body work is just around the corner.
Old 01-19-2008, 09:20 AM   #50
vern350
like a rock
vern350's Avatar
its been awhile since i've updated this tread. Truck really hasn't been touched. I now have a very solid cab for it. I just purchased a 6" rough country lift kit for it yesterday. Other projects, school, and work have put this truck on hold. Openfully have it back in the garage within 2 weeks.
