Old 01-18-2007, 12:59 PM   #1
clean71
clean71's Avatar
What to Do??
Have a 72 Jimmy w/original drive train. Don't plan on selling anytime soon, but.... Question is should I rebuild the original 350 or drop the $$ on a ramjet 350? or....Can spend about 6k total. What do you guys think?
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 01-18-2007, 02:22 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: What to Do??
Keep the original for the value later on and drop in that Ram Jet now!!!
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 01-18-2007, 02:24 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: What to Do??
If you're going to restore the rig to original, rebuild the engine. If you want an updated or modified, nice driver, go with the ramjet.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-18-2007, 03:06 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
Re: What to Do??
Just go ahead and spring for the new engine to get things up and going, but NEVER get rid of that original sbc! Rebuild it later when the time is right.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-18-2007, 11:28 PM   #5
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: What to Do??
Good advice...I pulled my original motor out a while back and threw EVERYTHING away and now i'm buying it all back one piece at a time. The ramjet is about 4900 when I looked at it so that leaves 1100 for a nice brand new serpentine belt drive on the front (549 w/o air, 749 with air). Just add headers and you should be good to go. It's tough though because if you went to a reputable machine shop and got a good rebuild with some aftermarket heads, cam, intake, etc, etc, you get make a lot stouter motor in my opinion; even a nice 383 for the same if not less money but you'd have to stay carbureted. Personally i'd go with the rebuild and hop it up a little. If you didn't go crazy on the rebuild you could drop the Edelbrock EFE kit and stay within your budget and make more power too. The ramjet sure is convenient though.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 01-19-2007, 07:26 AM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: What to Do??
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-19-2007, 08:55 AM   #7
Huck
Huck's Avatar
Re: What to Do??
Depends on what you want to accomplish. For cheap power, have the original rebuilt but use newer vortec heads, efi, HEi~~~and off you go. If normal driving, spring for a new crate mtr. You will probably enjoy a different transmission even more then the motor!! Overdrive make old trucks a lot more useable and enjoyable. IF offroad, go for broke as it will make you broke.
Huck is offline   Reply With Quote
Old 01-19-2007, 10:24 AM   #8
Burt4x4
Burt4x4's Avatar
Re: What to Do??
Drop in a 454 and have FUN
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-19-2007, 03:17 PM   #9
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: What to Do??
It also depends on if there are any other goodies that you may want to buy for it(the Jimmy).
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 01-19-2007, 03:26 PM   #10
69BLAZYA
Re: What to Do??
ramjet would let you enjoy it more less screwin' around with the carb ..
69BLAZYA is offline   Reply With Quote
Old 01-20-2007, 12:57 PM   #11
Mike C
Mike C's Avatar
Re: What to Do??
I'm with Huck. Why not find a low mileage take-out 5.7 with 4L60E? For about $2500 you can have a late model motor, FI, overdrive, AND the serpentine drive setup.
Just depends on down time I guess. You really need a second vehicle to pull the swap off realistically IMO. But that should leave you $3500...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
