01-21-2007, 09:45 AM | #1 |
1970 Blazer floor covering
Does anyone know where to get new reproduction rubber floor mats like the one installed in the blazer? This was a step below carpet and was wall to wall, had a pattern in it and covered both front and back sections of the blazer. ACC seems to have the front, which is same as truck application but doesn't seem to have the back. I like the old school look of it and wanted to go back with it but all I can find is carpet. I can find a rear mat but it is plain without a pattern. Anybody had any luck or am I just being silly?
01-21-2007, 04:37 PM | #2 |
Re: 1970 Blazer floor covering
here is pics
01-21-2007, 05:59 PM | #3 |
The LuvShack Garage
Wowsers, I have never seen one in that good of shape, just be blessed you have it
01-21-2007, 06:07 PM | #4 |
'72 K-5 4WD, 350HEI, TH350, 4" Lift, Work in progress |
01-21-2007, 06:29 PM | #5 |
SKINNY TIRES RULE!
I'd guess just about any of the vendors on the board can get the rubber blazer mats too. I need to replace mine too. I have heard that the sound/heat deadener under the the mat contains Asbestos so wear a mask when you remove it.
FYI, in the rear section, there are some mats under the main mat that level out the surface. Don't loose those, nobody makes repops. Nice lookin' blazer...
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
01-21-2007, 11:18 PM | #6 |
LMC does not make them or sell them, I went to the city counter in KC and it was not correct. From a distance mine look OK but really they are toast. I do have to check out classic industries as they advertise in catalog they have the correct ones,anyone have any experience with them?
01-21-2007, 11:24 PM | #7 |
Like these? Got them!
01-22-2007, 12:35 AM | #8 |
SKINNY TIRES RULE!
Yep. Those are the one's I'm talking about. Let me know if you find reproductions of the originals. My rear mats are in good shape, but the front is cracked in several places.
Your Jimmy has some interesting option combonations. You have the side trim with utility buckets. I'm not sure I've ever seen those together.
01-23-2007, 12:39 PM | #9 |
Bouncy, my 70 Jimmy has the side trim with utilities also.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
01-23-2007, 06:13 PM | #10 | |
They are definitely in LMC's catalog. There is an old thread somewhere in here that has another source. I believe that one was direct from the manufacturer, and probably the same ones that LMC sells.
Tim Last edited by Blazer1970; 01-23-2007 at 06:14 PM. |
