Old 01-22-2007, 03:04 PM   #1
sleepyboy
'69 Step
Do I need an adjustable panhard bar
My truck was lowered 3/5 by the P.O. I was wondering if I needed an adjustable panhard bar? I am in the process of bagging the truck and replacing the trailing arm bushings. Will not changing the original panhard bar mis-align my rear end?
sleepyboy is offline   Reply With Quote
Old 01-22-2007, 03:18 PM   #2
53lowdown
Junior Member
53lowdown's Avatar
Re: Do I need an adjustable panhard bar
I talked with a guy at early classics about this. He said to check the level of your panhard - and if it's already running uphill on the differential end - then every time your suspension compresses, it'll pull the rear to the driver side.
Mines running uphill now so I'm going to just move the mount on the rear end down a few inches until it levels out at my current ride height.
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 01-22-2007, 06:33 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
I would bet your rear end is out of alignment now. Measure between the tires and frame, and from the front wheel to rear wheel. This will put you in the ballpark. After finishing your work get a 4 wheel alignment at an independent shop. They usually do better with custom jobs..
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-22-2007, 06:52 PM   #4
jimmydean
jimmydean's Avatar
When I bagged my truck, I got the CPP Deluxe Track bar that runs from the passenger trailing arm to the stock frame mount. The longer the better.
jimmydean is offline   Reply With Quote
Old 01-22-2007, 11:28 PM   #5
jsbgump
Gone Fishing
jsbgump's Avatar
They say when you go over 4 inches in the rear you need the adjustable panhard bar
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
