Old 01-23-2007, 12:07 PM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Anyone have pics of their rear air bag setup?
I am gathering parts together to install my bags on the rear of my truck. It's a coils spring setup so any pics would help.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 01-23-2007, 12:22 PM   #2
abadsvt
abadsvt's Avatar
Re: Anyone have pics of their rear air bag setup?
So are you lookin for ideas or more of how others have theres setup? Here is my setup which is a little different that you might be looking for but I am proud of my setup so i will post it anyways. So what kind of rear setup where you thinking about going? Trailing arms with bags? 4 link and bags? Anyways good luck with your project
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-23-2007, 12:24 PM   #3
jimmydean
jimmydean's Avatar
I don't have a pic. I tried to find one because I know 67Fleet posted one of his (mine is the same). I just replaced my coil with the Slam Specialties RE7 bag.
There is the long bolt from the bottom of the trailing arm to the center mounting hole on the bag. Then there is a hole on either side of the center in the top of the arm.
Then there are 2 mounting holes in the spring plate and the 1" hole for the fitting. The hardest part is the hole for the fitting.
<edit> as well you should be proud of that setup, Josh. It's awesome!
I think Zumo is on a budget for his shop rig though.
jimmydean is offline   Reply With Quote
Old 01-23-2007, 12:30 PM   #4
Zumo
Hot Rods For Life
Zumo's Avatar
Wow. I am only able to go the basic route now, but that is awesome. I am basicly replacing the coil springs with bags.
Andy
Old 01-23-2007, 02:27 PM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
With bolt-in c-notch....
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-23-2007, 02:38 PM   #6
Zumo
Hot Rods For Life
Zumo's Avatar
Are you pretty happy with that setup. I plan on a bolt in C-notch as well, but later on. I want to get the bags up and running right now.
Andy
Old 01-23-2007, 03:23 PM   #7
jimmydean
jimmydean's Avatar
If you don't do the notch right now, the axle will be too close to the frame. I used a cup on the top that has a hole in the side for the hose. i will see if i can get a picture tonight.
With the 3" cup, at full dump the axle is resting on the factory bump stop. I will take the cup out once I get the notch installed and I trim my front cup.
The cups I used in the rear are the ones with a single bolt. I threaded the bolt and cut it down, it is mounted to the top spring retaining hole. Again, I will try and get a picture so it make sense.
[IMG]http://www.*****************/images/products/S10_Single_Port_Bolt_In_Front_Cups.jpg[/IMG]
Old 01-23-2007, 03:42 PM   #8
Zumo
Hot Rods For Life
Zumo's Avatar
I have cups also. Thanks Jimmy.
Andy
Old 01-23-2007, 10:43 PM   #9
bagged74
its just $$$$$
bagged74's Avatar
heres mine. I built new trailing arms to get a little more drop.
bagged74 is offline   Reply With Quote
Old 01-23-2007, 11:11 PM   #10
64hotrod
64hotrod's Avatar
Where did you guys get your bags from? I want to order front and back but I want to make sure I order right the first time. Thanks for any info.
'64 c-10 short stepside
400 sb or 402 bb/ th400
rebuild,ongoing project,can of worms.
'71 c-20 long fleet for parts
'69 c-10 long rolling frame
'70 c-20 long fleet work truck
64hotrod is offline   Reply With Quote
Old 01-23-2007, 11:42 PM   #11
jimmydean
jimmydean's Avatar
I would get everything from Suicide Doors if you are looking for a basic bag setup. The guys there know what they are doing and the price is the best I've found.
They have a "build your own kit" page that lets you pick everything but the brackets and fittings.
Old 01-25-2007, 07:15 PM   #12
n2billet
Village Idiot....
n2billet's Avatar
Here's mine on my red 68, bags bolted directly to the frame and trailing arm, 2 inch blocks and welded in c-notch......
n2billet is offline   Reply With Quote
Old 01-25-2007, 08:51 PM   #13
SCOTI
SCOTI's Avatar
Zumo.... I might be able to help you get a 'budget' rear set-up going if you need some help. Budget means bags, DOT air line, & schrader valves for filling. Cheaper than the full nine yards & effective.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-25-2007, 09:24 PM   #14
64hotrod
64hotrod's Avatar
Thanks jimmydean, I'll check them out.
Old 01-28-2007, 04:40 AM   #15
SlammedDime
SlammedDime's Avatar
Forgive my ignorance on the early style trucks and why you guys do as you do, but based on that picture, it looks as if your axle is just about bottomed out in your notch, and the bag isn't fully compressed. Why not remove that 2" block to allow the bag to compress more and allow yourself to get more lift?
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
Old 01-28-2007, 06:10 AM   #16
jimmydean
jimmydean's Avatar
If I'm not mistaken, that bag is aired out about as far as it goes. The internal bump stops keep the bag from going too much flatter.
Old 01-28-2007, 10:01 AM   #17
Alvin
Never Done?
Alvin's Avatar
Also by running the 2" blocks you can achieve a ride height (set @ optimal bag height) that is 2" lower than if you didn't have the blocks.
In effect, your making use of the additional clearance provided by the c-notch all the time, and not just when you're aired out.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 01-28-2007, 12:34 PM   #18
SCOTI
SCOTI's Avatar
Without the block, to acheive a drop equal to 7" requires almost no air pressure in the bag which makes for a 'choppy' ride. By using the blocks for additional drop, you need more air in the bags getting closer to optimal pressures for the best over-all ride.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2007, 01:01 PM   #19
poorboy
poorboy's Avatar
What is the optimal pressue?
poorboy is offline   Reply With Quote
Old 01-28-2007, 01:14 PM   #20
jimmydean
jimmydean's Avatar
It depends on your truck, but the optimal ride height for an RE7 Slam Specialties bag is 5" (IIRC). That is about 60psi in the front and 35psi in the rear on my truck. I know that makes for a nice ride at least.
Old 01-28-2007, 01:26 PM   #21
SCOTI
SCOTI's Avatar
I'm not sure if there is one answer for this question. Like Jimmydean, my Beater likes 35psi out back. Less than 30psi & it really is noticed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2007, 04:42 PM   #22
SlammedDime
I've seen firestone bags compressed far more than that.
I do understand that, but perhaps I'm just used to seeing people wanting to get the most possible lift. Rarely do I see guys setting up their bags so that their ride height will be at the bags design height.
Matt
Old 01-28-2007, 05:23 PM   #23
madiron
choppin it up
madiron's Avatar
i think they are slam bags with the internal stops im pretty sure firestones compress more than slams
living the low life
madiron is offline   Reply With Quote
Old 01-28-2007, 05:33 PM   #24
Alvin
Never Done?
Alvin's Avatar
I suppose that's the difference between some of us and most of the mini-truckin' / frame draggin' crowd ?
Sometimes it's all about the "show" side of it, and in that case an absurd amount of lift might be your thing (especially if you body drop it or something). But I just want to have a decent ride at a low height. No dragging or laying frame for me!
Old 01-28-2007, 05:34 PM   #25
Slammed67
Progress = 0%
Slammed67's Avatar
Yeah, why would anyone want to design their air suspension correctly?
The min. height of a Firestone double convoluted bag is 3".
