01-24-2007, 01:35 PM | #76 |
Sb 400 club
Re: How to lower my ride? Please help a newbie.
Sorry to be off topic but that is one fine truck you got there sir. I have never seen a long stepside here in person much lesss a long stepside manual trans. I was just wondering how your truck is viewed in Germany? I bet they are very uncommen although i do see a few people on this board from Germany. Was it brought over for by some company?
again nice truck and i like the idea of it on baggs!
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
01-24-2007, 01:51 PM | #77 |
@84 400
Thank you very much. The 73-87 are not so uncommon as you might think but I have the only long stepper here as far as I know. evrey time I drive it it gets a lot of attention, especially since I have lowered it. I bought this truck several years ago from an American business man who has been living here with his German wife. He went in financial trouble and so it was my turn. I felt in love with it at first view and now step by step I try to turn it into the way I like it. |
01-25-2007, 02:13 PM | #78 |
Hey guys is this topic too boring for you or is there just no experience with the ART strong arms or suicide?
01-25-2007, 02:48 PM | #79 | |
John |
01-25-2007, 03:24 PM | #80 |
@pcmcobra
I sent you an pm. What did Shane told you about advance or diadvance on these arms. If I get boxrodz right then they are only a help in alignment. And then I think they are damn expensive. My personally thinking was as I mentioned about that they help to creat some more clearence under the truck and give an additional drop. |
01-25-2007, 05:02 PM | #81 | |
Until Seventy Times Seven
To answer your other question, here’s a quick rundown: To start off with, you could use the cups and brackets for single port bags that Suicide Doors offer for the 67-87 trucks (http://*****************/67-87Fullsiz...Brackets.php#). [IMG]http://*****************/images/products/mid_67-87_Fullsize_Chevy_Single_Port_Brackets.jpg[/IMG] The upper bracket mounts to the outer flange of the spring pocket on the crossmember with 4 fasteners. The cup installs in the spring pocket of the LCA without the use of fasteners. You may want to section about 1 inch out of the cup to have the bag sit lower in the LCA without risking the air bag rubbing on any surrounding components, and thus lowering the ride height in the front. For this particular application, you should go with a double-convoluted style air bag. (vs. the sleeve-type air bag). To handle the weight of these trucks, the Firestone 2600 model (224c) is a popular choice. They are available as a single port bag. (Unless you are setting up a very radical system, I don’t see a reason for dual port bags.) They are set up at a ride height between 5” – 5.5” and can handle a weight of 3,150 lbs. @ 100 psi. The specs for Firestone air bags can be found on the Firestone web site (http://www.firestoneindustrial.com/r.../cscinfo.shtml) as well as on the Air Ride Tech (http://ridetech.com/productinfo/dimensions.asp). I can’t find the exact pdf that Firestone put out their air springs quite a while back. BTW, the Firestone site has some good information on installing and maintaining the bags as well. [IMG]http://*****************/images/products/mid_Firestone_224c_2600.jpg[/IMG] Although, Firestone is a popular choice, the double-convoluted bag offered by Slam Specialties have a strong following. They report that their bags don’t ballon like most traditional air bags and they are also more responsive as well. I’ve heard the ride is bit more firm than the Firestones. Their 7 series is a direct replacement for the Firestone’s 224c. You can found more information on the Slam Specialties web site (http://slamspecialties.com/). BTW, their bags are designed with a higher pressure rating. [IMG]http://*****************/images/products/res_SlamSpecialtiesRE200PSISinglePort.jpg[/IMG] Next, you’ll need DOT-approved air line and fittings. Among the choices for the size of the air line and fittings are 1/4”, 3/8”, and 1/2”. You may find a slow rise and deflate time with the 1/4” and too fast of a rise/deflate time with 1/2”. (Although, you can install rise/dump controllers to slow the air time of the 1/2” lines.) Then, if you want a fully automatic management setup, you’ll need to get valves like the ones that SMC offers, an air tank, a compressor, gauges (and 1/8” line) to read the pressure of each air bag and the other components (switches, leader hose, pressure switch, check valve, water trap, etc). Suicide Doors as well as many others offer a good selection. If you plan to maintain the air bags at ride height and not have a need adjust them on a regular basis, then you could forego the ‘accessories’ and plumb the air bags with Schrader valves installed on the ends of the air lines. Then, down the line, work on completing the system. Regardless, each air bag should be plumb independently of each other.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
01-25-2007, 11:53 PM | #82 |
good info boxrodz!!!!!
mike midwest images http://www.myspace.com/midwestpaintandmetal http://www.webshots.com/user/midwestimages http://www.midwest-images.com |
01-26-2007, 12:45 PM | #83 |
Thank you a bunch boxrodz, your information is great. I still read a lot of opinions in several articles but I think the slamsepcialities bags are the way to go. They offer the most raise and seem to be long lasting.
Regarding the air management I don't mind because I have the sure set, we talked about last year, installed. It is just a two way system but works great. The management sytem I want to fine tune with an high output Range Rover compressor and an five gallon tank. And if money is no problem I can turn to an automatic 4way system at every time. Now I have to figure out what fittings I will need. I thought about 1/2 lines. Do you think it will be too fast are is it ok? To be true a faster system I would appreciate because with no tank and the bags in my coils the system was rather slow. But I was able to drive nearly one year till one bag blowed. I guess I took too much preasure. Anyway thank you and maybe you have some additional advices for me. By the way does suicide ship international, it's not really clear on their site. Michel |
01-29-2007, 02:50 PM | #84 |
01-29-2007, 02:57 PM | #85 | |
I think you’ll find that the 1/2” lines may be too fast. You may want to consider 3/8” lines instead. Although, you may find that 3/8” line for the exhaust may be a bit too fast. But, you can add a reducer at the exhaust to slow it down, if necessary. I imagine your setup with the bag-assisted coil spring adversely affected the speed of the system. With the proper air management system, you’ll notice a difference in this bag setup vs. your previous setup. There’s quite a few diagrams floating around to help plumb the system like at the Outlaw Motorsports site(http://www.outlawmotorsports.biz/diagrams.asp). It's a be more extensive than you need, but the concept is usable. I don’t know if Suicide Doors ships internationally, but talk to Jason at Suicide Doors to find out. He is very customer service oriented and can help answer any questions you may have. BTW, I’d be interested to see how your setup works out. Especially, once you complete the Range Rover compressor/tank setup.
01-29-2007, 08:02 PM | #86 |
I should have pointed out that the 1/2" line/fiittings in the previous diagram can be replaced with 3/8" line/fittings and the 1/4" lines running to the gauges (cab) can be replaced with 1/8" lines.
01-29-2007, 09:00 PM | #87 |
It'd be alot cooler if you did
I find my 1/2" lines to be way too fast. I would tink 1/4" would be plenty, or 3/8" at the most.
The tubular control arms will get you slightly more clearance, but they will still be the first thing to touch the ground. at most I'd say they'll give you an extra inch over the stock arms that have flanges that hang down. |
02-16-2007, 09:14 AM | #88 |
What bags do you use for the rear? RE6 or RE7?
02-16-2007, 03:25 PM | #89 |
los-lowrider -
What type of suspension setup are you going to use in the rear (existing leaf spring, 4-bar, cantilever, ...)? For a rear mount bag above or behind the rear axle, a sleeve bag (ie. Firestone F9000s) would give you a better ride. You can use a double-convoluted bag (ie. RE7s), if you intend to setup a cantilever system for the rear.
02-17-2007, 04:03 AM | #90 | |
So nothing special, the only thing is the space which isn't really much. I plan to put both sides to the cap like N2TRUX did it. BTW, is it correct to get an extra drop by removing leafs? I read this several times but I am not sure on the effort of this. Is this caused due the lower capacity with minor leafs and if I would remove two leafs what drop would this offer? |
02-17-2007, 07:25 AM | #91 |
I just measured and a 6" bag should fit in front of the axle. Also the 7" for the front. Here are a couple of pics for you and the compressor for boxrodz.
02-17-2007, 07:29 AM | #92 |
2nd
02-17-2007, 07:32 AM | #93 |
3rd
02-17-2007, 09:18 AM | #94 |
And because I have the time today here is a little soundclip. It's really time to built a new exhaust system.
http://www.youtube.com/watch?v=mmPR0Ns9gfY |
02-18-2007, 02:31 AM | #95 | |
So, air over leaf should work out. I'd just imitate N2s setup. It looks like his setup uses the F9000s sleeve bags. Judging by your pics, it looks like you have the 9" - 9.5" space for the bag's ride height. The compressor looks cool. Do you have the specs (duty cycle, cfms/psi) on it? BTW, the engine sounds good.
02-18-2007, 10:43 AM | #96 | |
02-18-2007, 05:42 PM | #97 |
Thank you.
BTW, I read where some owners had problems with the air suspension system of their Range Rovers. Some converted theirs over to coil overs.
02-19-2007, 05:11 AM | #98 |
Burn Out video!
http://www.youtube.com/watch?v=zql1n9Z20c8 |
05-17-2007, 07:51 AM | #99 |
Well it took some time, I ordered bags, cups and plates at suicidedoors. The shipment took much longer than I thought.
Yesterday I started put thing together and test them. It seems that it works well with the airlift block. Additionally the cups are 1/2" lower now because the were to tall on my opinion. |
05-17-2007, 07:57 AM | #100 |
Please let me know your opinion!
