Old 01-28-2007, 03:17 AM   #1
corn
Drop spindle rotor question
how can you tell if a set of drop spindles are for 1" or 1 1/4" rotors? Im sure its a spindle diameter measurment but dont know what the differences are. Any help?
corn is offline   Reply With Quote
Old 01-28-2007, 03:40 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Drop spindle rotor question
the only way i can think of is to measure it by hand but somebody will enlighten us all soon
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-28-2007, 02:13 PM   #3
corn
Was planning on using my caliper but...
Old 01-28-2007, 09:00 PM   #4
68shortfleet
IIRC those two different rotors use different bearing I.D. so the spindle would also reflect that.
Jason
68shortfleet is offline   Reply With Quote
Old 01-28-2007, 09:26 PM   #5
corn
I appreciate the help here & not trying to sound mean, but I already said everything in my first post that was responded here. I need the measurements of the 2 sizes. Thank you...
Old 01-29-2007, 01:16 AM   #6
FLEET72
FLEET72's Avatar
After doing a little research I found out that "light duty brakes" equipped trucks use BR6 inner bearings and "heavy duty brakes" use BR5 inner bearings. Both use BR3 outer bearings.
From the SKF online catalog:
BR5
CAT-MSG TAPERED ROLLER BEARING-SET
CONE-LGTH 0.7200
CONST CUP&CNE
CUP-LGTH 0.5500
CUP-RAD 0.0500
GEN-MSG1 LM48548/LM48510
ID 1.3750
OD 2.5630
PRI A
PRI-PRNT Y
RAMS 4110
SMAC 5003
STANDOUT 0.1600
WEIGHT 0.5800
WIDTH 0.7100
BR6
CONE-LGTH 0.6600
CONST CUP&CNE
CUP-LGTH 0.4650
CUP-RAD 0.0500
GEN-MSG1 LM67048/LM67010
GEN-MSG2 COMPONENT OF KIT 23
ID 1.2500
OD 2.3280
PRI A
PRI-PRNT Y
RAMS 4110
SMAC 5003
STANDOUT 0.1600
WEIGHT 0.4200
WIDTH 0.6250
Sources and search criteria:
Parts America
SKF on-line catalog
1972 C10 2WD 402ci 4sp manual
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 01-29-2007, 06:07 PM   #7
corn
FLEET72, you are the man! Thank you...corn
