Old 11-13-2002, 10:29 PM   #1
ozarkhippie
Question Any pics of a factory 72 1 ton 4x4
Anyone have any pics of a factory 67 to 72 1 ton 4x4. Was there even one made? Just curious.
ozarkhippie is offline   Reply With Quote
Old 11-14-2002, 08:23 AM   #2
powermad
Hillbilly Hotrod
The 1 ton 4x4 made its debute in 1978. 14 bolt FF and a D60 front.
The 8 lug rigs of the 67-72 era are rated at 3/4 ton and quite a few will have an Eaton rear axle, and some have a Factory Detroit in them as well.
D44 fronts with the closed knuckle till 71 I believe. External hubs, big suckers too.
external hubs went till 76 then the internal ones. for 3/4 ton rigs.
In 78 The general decided to install a D60 front axle and call it a K30.
Either in a dually or a SRW rig, regular cab or a 4 door(3+3)
69 K5, .060 over 350/465/205.
powermad is offline   Reply With Quote
Old 11-14-2002, 08:50 AM   #3
Blazer1970
Blazer1970's Avatar
Actually, '77 was the first year for the K30. Definitely no such thing in '67 - '72 though.
Blazer1970 is offline   Reply With Quote
Old 11-14-2002, 09:04 AM   #4
ozarkhippie
I was going to say they had them in 77 because a friend bought his 1 ton 4x4 new in77. Ihave a 77 4 door single wheel 1 ton 4x4. Interesting both trucks use blocks under the springs and 2wd spring hangers in the rear. I have a 79 1 ton 4x4 that has the longer spring hangers to increase the ride hieght. I guess in 77 gm hadn't came up with the longer spring hanger for the 1 ton 4x4 yet. Oh the reason I asked if there were factory 72 1 ton 4x4 is there is a guy running around in one and claims it was a fctory 4x4. I guess I could of been a 1 ton 4x4 since new but I would probaly guess it was converted when brand new by a conversion co.
Old 11-14-2002, 03:43 PM   #5
ckhd
ckhd's Avatar
If it's a 67-72 1-ton 4 wheel drive, it's a conversion. Anyone that tells you different is either mislead or lying.
I'm pretty sure that the Dana44 went open knuckle in '70 (at least in Chevy). Not 100%, but I'd bet a Lincoln on it if I had to. I thought I noticed that in a service manual. I'll have to check.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-14-2002, 08:16 PM   #6
breeh
Recovering 67-72 Addict
breeh's Avatar
Just for the record. I had a late '69 with an open knuckle front end. I think '69 must have been a transition year. Gee, I could use a Lincoln.....
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-15-2002, 04:56 PM   #7
Yukon Jack
Yukon Jack's Avatar
My 69 is a closed knuckle and I think your right that it was a transition year. Mine has the Rockwell T-221 transfer case.
What does yours have?
Seems like most of the 69 trucks had the Rockwell, but not the Blazers.
Looks like were all in agreement that no 67-72 factory 1 ton 4x4's. Here is a pic of my good friend's 70 1 ton that he converted to 4x4. He did a great job.
More of it can be seen at http://www.j0ker.org/~yukon/tonys70.html
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-16-2002, 02:02 PM   #8
ckhd
ckhd's Avatar
I thought '70 was the transition year.
My '69 has closed knuckle with a rockwell. The service manual shows the '69 with a closed knuckle and the '70 with an open.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 11-16-2002, 09:36 PM   #9
buckshot
buckshot's Avatar
i thought in '69 the trucks had the closed knuckle but,the blazer came with the open knucle.
my blazer (a '69) has open knuckle/drum brakes/dana 20 transfer case.
ckhd,i've been meaning to ask you:what ever happend to the game & fish blazer that was auctioned off near you?did you break down and buy it?
buckshot
buckshot is offline   Reply With Quote
Old 11-17-2002, 12:50 AM   #10
breeh
breeh's Avatar
The '69 I was talking about was a 3/4 ton and it also had the NP205 transfer case with 4 speed. It was a loaded truck with AC and a NoSpin rear.
Old 11-25-2002, 07:32 PM   #11
mkmiller1
mkmiller1's Avatar
I had a '69 blazer as well with open knuckle front and 350/205 tranny/transfer combo. Bought from original owner who said the only thing changed was the weak 6cyl. for a 327.
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 11-26-2002, 12:37 PM   #12
ckhd
ckhd's Avatar
Buckshot,
I wish I had bought it. It went to someone local for $1600.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 12-11-2002, 05:28 AM   #13
Purs
Got Big Block?
Purs's Avatar
i'ts 3AM where I in Texas. I had to take a leak so I thought I'd take a look and saw this thread. I'm half asleep, but thought ya'll might like this pic. You've probabley already seen it.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 12-11-2002, 07:49 PM   #14
ozarkhippie
That would be nice wouldn't Purs. I bet those tires cost a good penny. I have a old duece and a half that looks to have the same front axle.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
Old 12-14-2002, 01:22 AM   #15
Milenko72276
Actually you can get the exact cut tires from usa6x6.com fairly cheap.That is a cool looking ride.Wish I had 2.5 ton axles under my rig.
72' Camper Special,454,th350,np205,4.56 locker,dana44 with spool,13" of lift and 44" boggers.soon to be 23" with rear disc brakes
Milenko72276 is offline   Reply With Quote
Old 12-28-2002, 01:30 AM   #16
Rod
Best story I've seen on 1 ton conversion. Lots of pics too.
http://www.ccountry.net/~tmobrien/trucks/napco/71napco/
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-28-2002, 09:19 PM   #17
ozarkhippie
Thats a nice 1 ton con. Rod. Can anyone tell me what kind of front axle that one is? Check out the steering linkage on that truck also.
Buy Sale or Trade
71 3/4 4x4
Old 01-01-2003, 10:07 PM   #18
Rod
Drivetrain: 1-ton "NAPCO" 4-Wheel Drive Front Axle, Rzeppa Closed Knuckle CV Joints/Steering Knuckles, Warn Model M-23 Locking Hubs, NP-205 Transfer Case, Heavy Duty (11,000 lb) Chevrolet Rear Axle, Dual Rear Wheels, Drum Brakes all around, 3.73 Ring and Pinion Gears.
Old 01-05-2003, 06:55 PM   #19
Couchsachraga
R U sure?
Greetings....
I'm here as I'm trying to get more info on a truck I'm going to look at-it's listed in the local want ads as a '69 1 ton, dually (with flatbed dump) 4x4.... So might this NOT be a factory set up?
Any info, thoughts would be appreciated...
Couchsachraga
Couchsachraga is offline   Reply With Quote
Old 01-05-2003, 07:31 PM   #20
racedvl
racedvl's Avatar
I think they would have to been done aftermarket. . . .
racedvl is offline   Reply With Quote
Old 01-05-2003, 07:54 PM   #21
Couchsachraga
Greetings...
Just spoke to the fellow-'69 flatbed dump, dually, 4wd, he assumes it's a one ton because of all the springs and does not know of a designation on it (e.g. c20, c30, etc...). He bought it from someone using it to haul wood and has used it to haul construction debris to the dump.
It's got a newer 350 in it mated to a 4 speed.
Cab corners are rusty (he filled them with expanding foam).
Needs new lockout hubs (he says they dont' lock anymore).
Any thoughts as to its value (northeast US)? Time to price hubs....
Thanks,
Couchsachraga
