01-28-2007, 04:40 PM | #1 |
lt1 in a 70 blazer
i wanted to get some insight on what i got my self in to i got a 94-96 lt1 engine with no computer or wiring. has anyone had any luck with the painless kit with the com. and the harness together? and do i have to run a return line back to the gas tank, and what kind of gas line should i use? i am trying to get everything set up so there is not that much down time on the blazer, if i can do some things before i take the motor out and stuff the lt1 in it thanx for any insight on the task
01-28-2007, 05:15 PM | #2 |
Re: lt1 in a 70 blazer
Doing a Painless kit right now for my TBI swap, seems to work out pretty well.
There's alot of stuff/wires you may not need/want/use but everything you 'will' need is there. Not sure about what the LT1 needs but a TBI set up needs 15 psi and a TPI needs 45 psi for fuel pressure. All will need a return line. You have the comp. already or your going to get one? |
01-28-2007, 05:31 PM | #3 |
The LuvShack Garage
From West TN
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
01-28-2007, 05:37 PM | #4 |
01-28-2007, 06:32 PM | #5 | |
Mike
Mike Redpath |
01-28-2007, 08:28 PM | #6 |
Cereal Killer
look at tanksinc.com for the fuel pump solution.
01-28-2007, 08:33 PM | #7 |
i dont have a computer i was looking at the painless harness and computer but it kind of expencive 1400 of the kit. i am going to run the 350 auto tranny that is stock with a rebuild kit already done and a 400 torque converter i had a tank built years ago 30 gal. so i thinking about a inline fuel pump?
01-29-2007, 12:13 PM | #8 | |
Mike
Mike Redpath |
01-29-2007, 03:30 PM | #9 |
Sounds like you might consider a carb. The computers can be had for a couple hundred maybe less out of a wrecked car.
