steering box
I've got a 67 c10 and my steering box is real loose. I've posted a thread about it a couple of weeks ago. Well I tried to tighten it up but that didn't seem to work. Also somebody told me to check the fluid level in it but can't break the bolts loose not sure even if it was low if it would solve the problem. So I was wondering do they sell a rebuild kit for these or is it not worth the hassle. Should I just go buy a new one , they are very pricey or is there another model vehicle i could pull one at the scrapyard and use it. Or does anybody got an extra one they are looking to get rid of. Thanks!
![]() ![]() ![]() 67 C10 SWB 350-Turbo 400 tranny-Disc brake "Those who live by the sword get shot by those who don't" |
Re: steering box
Manuel or power steering?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Re: steering box
Power steering.
Outlandish Trends - FL
Re: steering box
it's most likely you front end components that need replacing. ie: ball joints, inner/outer tie rods, etc. I'd replace those first, or at minimum check them for excessive wear.
-Bret 67 short-fleet sold! |
Re: steering box
It's got all brand new tie rods, ball joints, everything but steering box and drag link.
Re: steering box
Did you check or replace/rebuild the rag joint yet?
#7 | |
Semi-Senior Member
Re: steering box
You've got power, what bolt are you trying to loosen to check it?!?!?! Just use the dipstick on the p/s pump! Have someone rock the steering wheel back and forth, about 4-6 inches. Look for any side to side movement in any of the tie rods & pitman arm (off steering box). Check for looseness in the rag joint or any of the steering rod coming from the column. Check if the box is loose from the frame. Do this with the engine running. How much play? Stand outside the truck with it running while rocking the wheel back and forth. Measure how many inches the wheel moves from front tire movement one direction until it starts to turn the other direction.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab Last edited by 68speedalert; 01-29-2007 at 04:51 PM. |
member #16
![]() Join Date: Dec 1999
Re: steering box
Do you have the 67 style P.S. with the cylinder on the center link? Or the newer style? I think most have been updated.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
