![]() Join Date: Jan 2006
Compression Test 1976 305
I finally did a compression test and was wondering if these numbers are good or bad. The test was done on a cold motor. Initial compression on all cylinders came up fast and maxed out at numbers listed.
#2 130 #1 125 #4 130 #3 130 #6 130 #5 135 #8 125 #7 140 injected some oil into #8 cylinder and compression rose to 130. Thanks for all of your help Rick |
In Memoriam...
Re: Compression Test 1976 305
I know very little about compression, but the #'s look OK to me. Looks like even wear on all cylinders. IIRC, ideal is 150 PSI with 10% or less variation between all cylinders, which you have. Your rings are probably showing a little wear.
I can't comment on the cold vs. warm engine testing.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." Last edited by FarmTruk; 01-29-2007 at 11:45 PM. |
Yep , pretty standard for a 76. If its not smoking then you can get a little more time out of her.
shows your valves and head gaskets are intact not bad readings at all
great!! I'll clean her up and keep her going!!
ttt
