no start
im not gettin any spark on my 70 lwb 6 cyl... i tried a different coil even though i tested it, i used jumper wires to the coil..., i checked the coil for voltage durring cranking..., i cleaned the rotor and cap and inspected all the plugs... im thinking it has to be the points or somthing inside the distribuor. any ideas
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
Re: no start
its wierd cuz it ran the night before great and no start this morning... anyone got any clue?
Active Member
Re: no start
Has it ever run? Tried jumping coil to starter? If that is good I'ld look seriously at condenser. Swapping points and condenser is only about 10 bucks, and is an easy fix.
70 K5 350/350 Air Dave |
Re: no start
thanks, im gonna try the points and condeser next and yes it was running great 12 hours b4.. yeah ive tried jumping the coil right to the starter motor and the battery... no spark at all...
I'm a poor spectator
Re: no start
Make sure that nothing is touching that shouldn't be inside the distributor. If the wire that passes through the distributor body is cut and touches against the distributor you will not get anything. If your getting spark at the end of the coil wire (disconnect it from the top of the distibutor and set it near the block and turn the engine over, it should spark out the end) the points are good, if not check points. If you don't get spark at the spark plug (pull plug and hook back up to wire and crank over, it should spark) it's probably cap and or rotor.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Re: no start
when was the last time the dwell was set?? it does need regular maintenance
Future TOTM Winner
Re: no start
I say condenser beings that it just stopped overnight (literally). Did you get it fixed?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
