Old 01-31-2007, 11:08 AM   #1
imarodder
imarodder's Avatar
New around here,sorta
Hi guys I'm kinda new here..I was on here a few years back,when I had a 72 chevy c10..That truck is gone and I've bought and started a new project..Now my extra money is going into a 50 chevy 1/2 ton swb street rod project,that I've had a love/hate relationship with for about 3 years.I have had it subframed with a 79 camaro stub,it has a disc brake posi rear out of a mid 80's t/a,and i am going to run a goodwrench 350 4 bolt main/700r4(rebuilt with corvette servo,shift kit,and rewired lock up)..Tilt column with no key switch out of a chevy van..power brake booster/master cyl.,out of same 4wdb t/a. I got a heck of a deal on new bedsides/front bed panel/and running boards,so that will save me time on that ..Right now I am focussing on rust repair on the cab,that i thought was in decent shape,boy was i wrong!!!I am in the process of installing new front floor pans,inner/outer cowl panels,and floor supports..Then i will replace the cab corners..That should keep me scratching my head for a while, then I can get on to the good stuff..I will try to post some pics of the truck..Thanks,I look forward to reading the new posts,and checking out all of your current projects..
50 chevy street rod in progress,or regress depending on the day,(mostly regress!!!)
imarodder is offline   Reply With Quote
Old 01-31-2007, 11:49 AM   #2
pgf545
pgf545's Avatar
Re: New around here,sorta
Welcome back and post lots of pictures. I am doing the floors, inner cowl and 1 outer cowl panel on my dads truck right now. Good luck
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 01-31-2007, 03:01 PM   #3
stevehsd
stevehsd's Avatar
Welcome back!
Sounds like you've got a good start. I'm still trying to sort out the running gear on mine.
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd
77 FLH
stevehsd is offline   Reply With Quote
Old 01-31-2007, 05:00 PM   #4
CAL 58 GMC
CAL 58 GMC's Avatar
Welcome back to the board from central Califorina!
CAL 58 GMC is offline   Reply With Quote
Old 01-31-2007, 06:18 PM   #5
RabidScott
RabidScott's Avatar
Welcome back!! Looks like you have your work 'cut out' for you!!!
RabidScott is offline   Reply With Quote
Old 02-04-2007, 07:19 PM   #6
Daniel U
Daniel U's Avatar
Good Luck and welcome back!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
