Old 02-01-2007, 01:37 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
new 7004r rolls in park
i have just installed a 700r4 into a friends 1976 chevy van. i have attached the shifter and the thing roll reguardless of what gear its in. what might be causing this? how many gears does the 700r4 have that the shifter could go through?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 02-01-2007, 02:21 PM   #2
75sierraclassic
75sierraclassic's Avatar
Re: new 7004r rolls in park
Are you sure that you have the gear selector indexed correctly? It should have 7 positions. Park, Reverse, Neutral, Overdrive, 3,2,1.
The previous tranny probably only had 6 positions.
75sierraclassic is offline   Reply With Quote
Old 02-01-2007, 02:32 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
You could always pop the linkage off, and try to put it in park by hand. That way you'll know for sure if the problem is the trans or the linkage.
Slonaker
BTW, hello from just down IH35. I went to SWT in the 90s.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Last edited by Slonaker; 02-01-2007 at 02:34 PM. Reason: added unimportant San Marcos comment :)
Slonaker is offline   Reply With Quote
Old 02-01-2007, 02:46 PM   #4
krue
Designated A-hole!
krue's Avatar
I'd disconnect the linkage, place it in park on the tranny, see if it doesn't roll. If it doesn't roll, put the shifter in Park and connect the linkage and see what happens.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-01-2007, 11:05 PM   #5
crm318
crm318's Avatar
well the original transmision was a th350. when i jam the shifter all the way to park, it goes as far down as it goes and still rolls. i will do it by hand and get back to yall.
1972 Cheyenne
Old 02-01-2007, 11:25 PM   #6
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I have seen brand new transmissions come in from GM hydromatic and Allison with missing park pawl tangs on brand new trucks before. Maybe your trans builder forgot to install the tang. Disconnect the linkage then shift the trans into park by the selector shaft on the actual transmission first though, as others have stated.
DirtyLarry is offline   Reply With Quote
Old 02-02-2007, 12:22 AM   #7
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I would take the linkage off the transmission and turn the U-shape gear selector on the transmission all the way clockwise. It should have park if everything is right with the transmission. The U-shape piece is different from a truck to a van and they don't swap in one another at all. It will bolt up and work but your wont have park. On the van when its in park the u-shape piece on the trans should be strait up and down like 12 and 6. The one for a truck when its in park is slanted like about 10 and 4 all the way clock wise in park.
I don't think the shifter should need adjusted to get park . The only thing I would say it would need adjusted for is to get 1st gear. But that will keep the other gears from being right. The steering column is for a three speed not four so it doesn't let it down in 1st gear. You should be able to get all the other gears fine (Park Neutral Overdrive Drive Manual 2nd).
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
