Old 11-14-2002, 09:31 PM   #1
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
Question Drop spindle to top A-frame clearance
I nned a little info. I just put on a set of early classic's drop spindles. I noticed that when I check their turning stroke that they hit the top a-frame and will not swivel all the way. Is this because they are in an unload position, no engine with weight on wheels, or do I need to do a little trim work?
This is my first restro, so all this is new to me. I'll attach a pic. Maybe someone can see where I am talking about it hitting. I think it will be towards the right of the picture.
Any help appreciated.
Danny
polevault1977 is offline   Reply With Quote
Old 11-14-2002, 09:38 PM   #2
Alexis
Member since 2000
Alexis's Avatar
i didnt have this problem...put a jack under it and then try to turn it, see if it is cause you have no pressure
Alexis is offline   Reply With Quote
Old 11-14-2002, 09:58 PM   #3
gashog
Active Member
gashog's Avatar
My 2 1/2" drop McGaughy's spindles did the same thing when unloaded, They were fine with weight on them but I removed about 1/16th to 1/8th inch from the upper control arm just to be safe.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z
gashog is offline   Reply With Quote
Old 11-15-2002, 12:57 AM   #4
crazy4chevs
crazy4chevs's Avatar
clearance
I have the Early Classic dropped spindles and had the same concern so I called Early Classic. They said its fine, when the weight is put on it the gap will open up.
From other ones I have seen it should be about 1/4" or so with all the weight on it.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 11-15-2002, 07:56 AM   #5
polevault1977
Thanks for the info! Inquiring minds wanna know!
Danny
Old 11-15-2002, 05:22 PM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
I never noticed any problem like that with mine, at least not that I remember...I did mine 3 or 4 years ago...it should be perfectly fine once it's loaded.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
