Old 02-03-2007, 10:45 AM   #1
JMac11
JMac11's Avatar
Barke Part interchange??
Have an 84 with 10 bolt axles. Have found a set of axles with 3:73 gears that I want, they are out of a 77 model. Pretty sure they will fit, but I have just rebuilt all my brake system. Will the rotors and rear setups swap between years like this?? No one seems to know. Both sets are half-ton.
JMac11 is offline   Reply With Quote
Old 02-04-2007, 12:52 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Barke Part interchange??
Going by one web site I use looks like all the front stuff will swap over. On the rear if you have 11"x2" brakes all will be ok...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 02-04-2007, 07:43 AM   #3
Blazer1970
Blazer1970's Avatar
The front hub/rotor assembly will go right on the older axle. The calipers can stay on the truck. Rear, I have no idea. Worst case you have to buy pads/drums for the '77 rear.
Blazer1970 is offline   Reply With Quote
