Strong Arms (tubular) vs. Stock A arm
what's your opinion, when going with an air bag setup, are you having better luck with the stock arms or is the tubular upper and lower the way to go on a 1967-1972. in my case, who's going to see the tubular arms or is it money well spent to spend more.
thanks |
Re: Strong Arms (tubular) vs. Stock A arm
It depends. Nobody will see them, but they are nice. If your stock arms are in good shape, then stick with them. If your just going with a basic bag setup, then stock arms work great.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
True Addiction
My stock arms were in pretty bad shape, and who doesn't aftermarket
have pictures of your deflated?
ART's tubular arms offer revised geometry for the lower ride height vs. stock arms.
Junior Member
Some pics of mine! ART Strong Arms & CPP Drop spindles. Stock crossmember 1/2" off ground with 20's.
#7 | |
I will be switching to tubular arms at some point, but I am torn between that and the C4 drop member. It comes down to performance/bling vs. low and laid out.
Active Member
![]() Join Date: Oct 2006
Raguemoe that is a sick looking truck. What did you use for wheel well's?
Formerly LSC71
Adding the Strong Arms does give you 3 degees more caster than the factory set up. One more thing to consider if you are trying to decide what to do is if you are going to keep your factory arms and put all new bushings and balljoints in them it isn't much more to go ahead and get the tubular arms with all the new stuff already installed .
Texas Big Wig
Not trying to hijack the thread, but who has the best tubular A-arms for the money ?
Epoxy Primer Friendly
Trailer Fenders.
True Addiction
Nice truck Rague, What kinda of bags are you running, and whats going on out back for suspension. Thanks bro
Junior Member
They are modified trailer fenders by Devious Custom. I believe the are Firestone bags all around. Here are some pics of the rear 3-link!
Junior Member
Dude.. install and fab work look great! My only suggestion would be to upgrade to the new Kevlar sleeved bungee straps. With the original bungee I think you will notice wear thru and fatigue issues.....
#15 |
RAGUEMOE what kind of hood hinges are those? I'm having clearance problems
with my 20"
BIG ANTS 71 |
#16 |
Junior Member
They are Mercedes hinges (very strong-no side movement).
#17 |
Señor Member
I'm not so sure we want to see his "deflated"
#18 | |
Questionable
Another question to ask may be, "who makes tubular arms that use the stock 73-87 balljoints?" ![]() At least - after mulling over the comment above (and researching to find) that it'll cost me $250-300 to buy replacement bushings, etc. and I'm going to hafta pay $50/ea pair to have my arms sandblasted and coated...it almost makes more sense just to spend the add'l $300 and get tubulars all the way around. I found that Godfather Customs here in town has the DJM 73-87 tubulars for around $600 out the door (with 10% off, no tax and free shipping, if possible. Sorry for the year-old post bump, but I just haaated seeing questions go unanswered ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-01-2008 at 08:50 AM. |
#19 | |
#20 |
Formerly LSC71
[QUOTE=shifty;2598188]......
Another question to ask may be, "who makes tubular arms that use the stock 73-87 balljoints?" QUOTE] The Air Ride Technologies tubular arms use the stock size ball joints. You can order them for any year truck 63-87 and they will have the correct ball joint combo for your year, or you can order the 73-87 set up for those spindles if you wanted to put the factory style disc brake kit on the front of your 68 for example. We use the 73-87 style of upper and lower cross shafts that allow them to fit all of those years with the ability to interchange the different ball joints in the same control arm. You can pretty much come up with any combo for those trucks and still make it work. If you guys have any more specific questions feel free to give me a call. My name is Craig, my direct line at Air Ride Tech. is 812-481-4707 |
#21 | |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#22 |
Formerly LSC71
#23 | |
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#24 |
Formerly LSC71
#25 |
Questionable
10% + free shipping and you got a deal
![]() Paypal or otherwise, I'm all fired up and ready to go ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-28-2008 at 12:20 AM. |
