Old 02-05-2007, 06:14 PM   #1
bill weber
1969 c-20 front disc brakes
I have a 69 c-20 with front drum brakes. I would like to convert to front disk from junkyard parts.What year trucks would work with out modification? Thank You.
bill weber is offline   Reply With Quote
Old 02-05-2007, 08:50 PM   #2
aesj2
Re: 1969 c-20 front disc brakes
IMHO this http://www.p-s-t.com/truck/tvfdbk3.html would be your best bet. No junkyard parts to deal with and they have a 6-lug kit.
Just noticed that link is for 1/2 ton. If you can find a 71-72 C-20 that would be easy, without much modification.
aesj2 is offline   Reply With Quote
Old 02-05-2007, 09:52 PM   #3
Terry'sToy
I'm doing the exact same thing on my dads 67. I need answers too.
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's
Terry'sToy is offline   Reply With Quote
Old 02-05-2007, 11:15 PM   #4
manimal
manimal's Avatar
Should be able to do the same as a 1/2t. 73-87 complete crossmember
manimal is offline   Reply With Quote
Old 02-05-2007, 11:19 PM   #5
qksilver
the only reason to swap crossmembers is so that you can drop the oil pan easier. Otherwise swapping crossmembers is a pain.
The later model 3/4 suspensions from 71-up to I think 87 or so , depending on it being a burb or a 1 ton will bolt on.
Unbolt the control arms from the later model and bolt them on to yours.
Using 73-up parts is better because of the ride, rubber bushings, plus the parts are cheaper. You will have to change out your M/C and proportioning valve because of the discs.
qksilver is offline   Reply With Quote
Old 02-06-2007, 10:48 AM   #6
rlm316
rlm316's Avatar
73-87 truck, 73-91 suburban. Not sure on blazer, need to look at body style. Check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=225796
rlm316 is offline   Reply With Quote
Old 02-06-2007, 12:48 PM   #7
Terry'sToy
many thanks from me.
Old 02-06-2007, 06:04 PM   #8
bill weber
thank you for your replys.It will be a lot easier to find an 80's truck to grab the brake parts from.bill
