holley carb & detent cable hookup
I put a much needed new carb on today. I was able to get the throttle adapter and cable hooked up, but I'm clueless on the detent cable (TH350). As far as I know I may not even have the right cable on there. Does anyone have any pictures of this type of setup? Also, what part #'s did you use for adapters or brackets? Thanks!
ureckmefixit2@cox.net
Re: holley carb & detent cable hookup
I used my stock bracket but spaced it up 1/2 inch.
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
I've been looking at detent cables, and I think I may have the wrong one installed. The cable I have has the linkage end that is open. Meaning it can move about an inch or so. I've seen pictures of linkage ends that pop onto a ball type stud that is bolted to the linkage. The one that pops onto the ball seems like it should be the cable that is on my '85, but I really don't know.
Guys try :
LMC ( page 43 ) or YEARONE here's a page from LMC
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine. 1967 Chevy 3/4 ton standard bed, 350 cu./400 auto, w/ 83 - 3:43 rear end...sips gas.... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
