02-07-2007, 08:30 AM | #1 |
Senoir Member
Rear axle u-bolt torque??
The manual is a bit confusing on how much to torque the rear axle u-bolts on a 2wd, 12 bolt, with the inverted square bolts (nuts under the axle). I have new 1/2 u-bolts. Thanks in advance. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
02-07-2007, 08:43 AM | #2 | |||
Union Electrician
Re: Rear axle u-bolt torque??
225 ft lbs it is not fun getting them to the setting. although the manual says 195-225, I went with the higher number.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
02-07-2007, 10:39 AM | #3 |
I'm watching you!
I didn't use a torque wrench on mine because of the wierd position I was in, but three long grunts pulling the bar with all my weight should have brought it close
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
02-07-2007, 11:08 AM | #4 |
Wrench until it hurts, then 1/4 more and you should be about right.
It too a 36" breaker bar and both legs to get mine off. After that, getting them on was easy.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-07-2007, 12:31 PM | #5 |
tighten them until they squeak...then half a turn
02-07-2007, 01:00 PM | #6 |
Senoir Member
Dang, that's sounds like alot for a 1/2" bolt. I'd hate to see what the 4wd u-bolts torque to, since they're a little bigger. Thanks, Greg
02-07-2007, 01:06 PM | #7 |
Jamie Hyneman is my twin
I torqued mine with a 30 inch bar, and all the strength I could muster. Not looking forward to ever taking them back off.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
02-07-2007, 02:49 PM | #8 |
~Rest In Peace~
if you going to take them off i would just cut them off and put new u bolts on
no grunt work here
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
02-07-2007, 10:32 PM | #9 |
I dont have a manual and im no expert but 225 ft lbs seems crazy.
i can tell you that every nascar team runs the same rear suspension as our trucks and with 3/4 inch u bolts torqued to 100 ft lbs. Im suprised they dont snap at 225 ??? |
