Old 02-07-2007, 11:12 PM   #1
CalvinF
Gas Gauge Trouble
I need some advice. Since I bought my '72 the gas gauge has not worked; so I just replaced the sending unit. But the gauge still doesn't read and if you unplug the wire on top of the sending unit (key on) the gauge then goes to full. As soon as I plug it back the gauge goes to empty again. What could be the problem???
CalvinF is offline   Reply With Quote
Old 02-07-2007, 11:16 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Gas Gauge Trouble
welcome to the board
rage'nrat638 is offline   Reply With Quote
Old 02-07-2007, 11:27 PM   #3
byrd
Union Electrician
byrd's Avatar
You probably have a short in the wire between the sending unit and the gauge. You should check for frayed wires or a splice somewhere along the wire. Yu can also just check continuity on the wire if you have a multi meter and BTW Wlecome to the board from KY !!
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 02-07-2007, 11:33 PM   #4
CalvinF
Thanks for the welcome. The info on this site has been great! I will try checking the wires as you recomended. Thanks!
Old 02-07-2007, 11:41 PM   #5
screamin_eagle
screamin_eagle's Avatar
sounds like my truck field mice made a home out of my truck chewing through random wires. I got all the lights working then quit. if i'm not sure how much gas is in it i just wip out my trusty old dipstick. good luck finding that short
screamin_eagle is offline   Reply With Quote
Old 02-08-2007, 05:57 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
I keep a log book. I figure it gets 10 miles per gallon on a 20 gallon tank. That gives me a range of 200 miles. I make sure I fill it again before 200 miles is up.
If it's not the wire, and the sender is new [and assumed to be good] the float could be bad. Leaky, defective or fell off during or after install. Sounds like the gauge is good if it reads (beyond) full when you unplug it.
'68OrangeSunshine is online now   Reply With Quote
Old 02-09-2007, 09:45 PM   #7
mnunn454
mnunn454's Avatar
If the gage swings one way when you attach the wire, then another when you remove it, then there's nothing wrong with the wiring or the gage.
Assuming the tank isn't empty (you're sure of this, aren't you?), I think the problem is one of 3 things:
Electrical post on sending unit shorted to ground
Float is sunk or stuck in the down position
variable resister inside the sending unit is bad.
Either way, you'll need to pull the sending unit and head for the bench.
Make sure the float is empty. Then using an ohmmeter, see if the resistance changes as you move the float arm. Check the specs to see what it should read. (0-600 Ohms I think, but don't quote me). Maybe one of our experts with a tech manual can verify.
My guess is the float is sunk, or something's wrong with the sending unit.
Good luck and let us know what you find.
And be careful with that open gas tank. We'd hate to loose a good truck from our collection.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 02-09-2007, 09:55 PM   #8
72chevy327
any one know what the Ohms should be. i hear it should be 0-90 Ohms.
72chevy327 is offline   Reply With Quote
Old 02-09-2007, 11:46 PM   #9
clay68c10
clay68c10's Avatar
Yup, 0-90 ohms.
I've seen a new sender read zero, the electrical connector pin wasn't centered in its rubber insulating grommet and was touching the body of the sender (short to ground). It's worth checking.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-12-2007, 09:30 PM   #10
mnunn454
mnunn454's Avatar
Originally Posted by clay68c10 View Post
Yup, 0-90 ohms.
I agree. Just pulled the sending unit out of my setup last weekend and it says 90 Ohms right on it.
Good luck.
Old 02-12-2007, 09:49 PM   #11
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I've had trouble with some repro floats being too heavy to float. Might be the problem if whole unit is a repro.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-12-2007, 10:12 PM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
