02-08-2007, 09:44 PM | #1 |
Is there a difference in tie rod sleeves?
I was looking at napa online and they list 2 different tie rod adjusting sleeves. One is listed as "manual" and is $16, the other os "power" and is $30.
My '69 was a manual truck and I added a power box. I am replacing my tie rod ends, so should I "upgrade" to the power sleeves? Is there a difference? My truck drives straight, but the driver front tire has worn on the shoulder in a matter of days. I figured I would replace the upper control shafts and tie rod ends. I replaced the ball joints when I installed the disc brakes. Is there anything else I should replace as well? The bottom shafts are tight. Thanks.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-09-2007, 09:52 AM | #2 |
Re: Is there a difference in tie rod sleeves?
I didn't have a full pic and its too cold to walk to the garage but here are the newer style from POL alot better than the old crimp style.
02-09-2007, 10:25 AM | #3 |
Where did you get those Ram-Man. I have been looking for that style for our trucks. The ones that Hotchkis makes are SWEET but they don't make them in the larger bore to fit our truck, only muscle car stuff that is smaller..
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
02-09-2007, 11:22 AM | #4 |
Yes, where did you get those? I used the disc setup from GMC Pauls, so I am still running my '69 tie rods. Have a link?
Found them here and they are only $50 for the pair!
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 02-09-2007 at 11:25 AM. |
02-09-2007, 03:01 PM | #5 |
18 Till I Die
will they work as a direct replacement on a stock 69 with drums up front??
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
02-09-2007, 03:17 PM | #6 |
I don't see why not. I am using the same tie rods and the order form say "specify year" so they must make a setup of 63-70.
02-09-2007, 09:10 PM | #7 |
Sorry for the wait but I got them from performanceonline.com They are really heavy duty I got them in the whole front end kit but here is a link for the seperate.http://performanceonline.com/store/c...cat=787&page=1
02-09-2007, 09:11 PM | #8 |
