Old 02-09-2007, 09:55 AM   #1
ocbaud
Garage Queen Material
improving fuel milege???
anyways to help with fuel economy in my truck???
any little bit help, it averages about 11mpg right now.
here are the specs on it
355ci
10:1 Compression Ratio
Holley systemaxII alum. heads
Comp cams 270H magnum
Holley street dominator intake
MSD Pro-Billet distributor #8361
MSD Blaster2 Coil
MSD 6AL Ignition box
Edelbrock Thunder Series 650cfm AVS carb
Aeromotive Billet Fuel Pressure Regulator
shortie headers
K&N 4" Open Element air filter
3.73 gears
Eaton Limited-Slip Diff.
Th350c transmission
2800 stall torque conveter
B&M Stacked plate trans cooler
trans-go transpack
i'm thinking a new carb, but the one i want is SO expensive (650cfm mighty demon)
and i plan on getting a built up 700r4, but those are expensive too and the torque converters are expensive for them too!
ocbaud is offline   Reply With Quote
Old 02-09-2007, 10:01 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: improving fuel milege???
It sounds like a built up 700R4 is the next step. That will be expensive, of course, which is why I don't have one.
I doubt you'll do much better than that with a TH350 and 3.73 gears. I'm surprised that your mileage is that high.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-09-2007, 10:15 AM   #3
ocbaud
Slonaker
i was telling angie i was gonna spend our tax return on a new tranny and a blower for my truck. she just laughed at me
Old 02-09-2007, 01:38 PM   #4
84slopwaggin
84slopwaggin's Avatar
Man you should just sell me that truck and get you a Nissan Hardbody for increased fuel economy .
84slopwaggin is offline   Reply With Quote
Old 02-09-2007, 01:50 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Putting a Demon on there would be going backwards in gas mileage in my experience. For mileage a spreadbore would be a better choice.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-09-2007, 01:58 PM   #6
ocbaud
ah i know, but it'll have MORE POWER!!!
its not like i drive the truck everyday
Old 02-09-2007, 02:38 PM   #7
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
MORE POWER usually equals MORE GAS...
If you don't drive it everyday... then don't worry about the gas mileage
CLASSIC87' is offline   Reply With Quote
Old 02-09-2007, 02:45 PM   #8
Prerunner1982
Prerunner1982's Avatar
I think fuel injection would be a good step for a bit of increased MPG and performance as well. Then a built 700r4....
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-09-2007, 02:54 PM   #9
ocbaud
if i was gonna spend that much money for fuel injection, i would much rather it go towards a blower
Old 02-09-2007, 03:08 PM   #10
SSC's76
No No
SSC's76's Avatar
Actually the Blower would increase your fuel economy as long as you drive like a granny. Only problem is that 10:1 compression ratio needs to drop a few points before the blower goes on.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 02-09-2007, 03:50 PM   #11
82c10
needin' money
700r4's suck, listen, if you are wanting to do that get a gearvendor's overdrive
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 02-09-2007, 04:02 PM   #12
Malo83
Cruzzzn' Vet
Malo83's Avatar
It's a tradeoff, with all those go fast goodies on the engine,10.1 compr. don't think it's gonna happen, since it's not your DD I wouldn't worry about it, cake is good but sometimes you can't eat it.
Malo83 is offline   Reply With Quote
Old 02-09-2007, 10:17 PM   #13
slugish
Slugish
Red face Re: improving fuel milege???
Consider putting a lower # gear ratio in ,like a 3.42 or 3.23. With your engine you would still have a good low end & be able to cruise without engine souding like its going to blow up. Ihad a 3.73 in my truck with the 3 speed turbo trans. but took it out . 350 / 3.73 is agood combo if you run mostly on the strip.
slugish is offline   Reply With Quote
Old 02-09-2007, 10:18 PM   #14
slugish
Slugish
What is a gearvender overdrive. Im interested.
Old 02-09-2007, 10:57 PM   #15
Slonaker
Slonaker's Avatar
For wgat one will cost, you could buy another truck. I'd love to have one, but not for that kind of money.
http://www.gearvendors.com/
Slonaker
Stock '01 Silverado
Old 02-09-2007, 11:33 PM   #16
79Silv4x4
Workaholic
79Silv4x4's Avatar
Dude, you've been around long enough to know the answer to this question.
If you are getting a true 11mpg with current setup do a happy dance .
These bricks are not gonna get 18mpg despite the constant claims we all see here.
79Silv4x4 is offline   Reply With Quote
Old 02-09-2007, 11:40 PM   #17
bulky
Bulky
bulky's Avatar
You could always do the "Poor Man's" Gear Vendor..... This is an old "DoodleBug" for sale up here locally. It has a 4 speed attached to a 3 speed.
2016 Silverado
1930 Model A Hot Rod
1923 Ford A/SR Altered - Injected 409
1982 Honda CB900F Super Sport
Dad's 1970 GMC 9' Stepside
Dad's 1969 GMC Custom Camper
bulky is offline   Reply With Quote
Old 02-09-2007, 11:52 PM   #18
ocbaud
i know i just wanted to post some more in here
yeah its about 11mpg a little less on the highway. not like it matters, the mustang gets 20mpg so i'm fine with that. the trucks had maybe 300 miles put on her in the past year
so i'm gonna end up buying the speed demon 650 carb, which means i'll have that 650 edelbrock and accessories for sale soon if anyone wanted to know
Old 02-10-2007, 08:23 AM   #19
grinch4om
dang its hot
grinch4om's Avatar
do the 700 tranny, I have one behind my big block witha 2500 stall(lock up) and it does 16-17 on highway at 65mph, of course thats no wind and good baro pressure yadda yadda....
grinch4om is offline   Reply With Quote
Old 02-10-2007, 12:07 PM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Screw mpg, just focus an ET and forget the rest...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-10-2007, 01:12 PM   #21
82c10
needin' money
it's slow
Old 02-10-2007, 01:13 PM   #22
boatpuller
boatpuller's Avatar
i agee,if you want mpg....get a datsun.
boatpuller is offline   Reply With Quote
Old 02-10-2007, 01:37 PM   #23
ocbaud
Originally Posted by 82c10 View Post
it's slow
haha its faster than my mustang.
Old 02-10-2007, 02:07 PM   #24
82c10
needin' money
what does the truck run, if i remember the stang is 13.80x
Old 02-10-2007, 02:46 PM   #25
ocbaud
the mustang ran a best of 14.2 @ 100mph
the truck ran a best of 15.09 @ 90mph with 2 flat cam lobes, open rear end with 2.73 gears and an untuned carb(which it still is)
