CoonHunter
vin on frame
I was just wondering where the vin was stamped on the frame at. I thought they were on top of the frame on the pass side under the door. Am i wrong?
72 Chevy 1/2 ton 4x4 4" inch lift. 2000 Chevy Malibu |
Fabricate till you "puke"
Mine is located on the top of the driver side rail, right next to the steering box
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#3 | |
Bloo
ive got one by the steering gear and under the cab on the drivers side
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
CoonHunter
There is a number there but it's starts with a oj something something.
#5 | |
Bloo
thats probably it,
0- 1970 J- assembly plant (maybe, dunno if there was a J one)
CoonHunter
Heres the number if you can help me. OJ153074.
#7 | ||
Bloo
![]() anyways, 0-1970 J-Janesville 153074-sequintal model number (53074 unit built) to get the rest of the info you need the total vin, like off the cab or glovebox, like mine is: K- 4 wheel drive E- came with a V8 2- 3/4 ton 4- fleetside box 1- 1971 S-St. Louis 673757- 573757 unit built im pretty sure that they started out with 100000 as first one built every year on the unit built number
![]() Last edited by Blue_71; 11-16-2002 at 02:39 PM. |
Just like to part out trucks!!
Yes they only stamp part of the serial # on the frame on the top of frame right beside or behind a little of the steering box. Its on the top of frame. Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
![]() Join Date: Dec 1999
Like said on Driver side upper frame rail and upper frame right under cab,b both mine reside on 67 GMC frames which came without vin on the frame,which makes it nice when i moved here and had to go through inspection on my 69 they Motor Vehicles looked everywhere didnt see any signs of tampering and were mind boggled going by the book,i just acted like I have no clue?after about 30 minutes of crawling up and under they just passed me.
