Old 02-11-2007, 11:35 PM   #1
robertish
door handle
hey all. new here.
ive got a 1982 gmc sierra and the plastic part of the outside door handle broke off.
Ive been to a couple of pick and pulls trying, but i cant seem to figure out how one removes just the little plastic button part. I have an easy time opening the door and can get as far as having access to the whole outer/inner door handle contraption, but cant seem to figure out this simple little task.
feeling a bit dumb but, i bet one of you has a trcik.
thanks a bunch.
also, if anybody has a diesel and wants to know more about running on veggie oil, i have some insights and personal experience to share, ive been running veg and biodiesel in the two tanks respectively. its been going pretty good aside from a little bit of trouble with the fuel pump in cold weather.
robertish is offline   Reply With Quote
Old 02-11-2007, 11:47 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: door handle
it the button on the door handle broke. I would guess u would have to remove the door handle from inside the door it two bolt easy enough to do just make shure to remember how it all goes back in. I think ive removed whole handle before but not just the nob
Srubydo1986 is offline   Reply With Quote
Old 02-12-2007, 03:11 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: door handle
you have to remove the handle to get the push button out.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-12-2007, 08:22 PM   #4
robertish
Re: door handle
captkaos, are you saying theres no way to replace just the plastic part, that the whole handle has to be replaced?
if thats the case all i need to know is how to remove the handle from the rod that connects it to the locking mechanism.
Old 02-12-2007, 11:42 PM   #5
steemin_ehman
False Lies
steemin_ehman's Avatar
Re: door handle
if u can get your hand and maybe a flashlight into the door and look where the rod connects to the hinge. there should be a little metal clip that you slide over (i think slide the clip towards the inside of the cab... or maybe towards the front of the door..) anyway, this frees the rod. i know it sounds easy, but mine took a little bit of manipulating before i got them off.
Kyle (Steemin) Ehman
-1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO"
-2015 Yukon XL Denali (Family ride)
-1977 Chevy stepside, carb'ed vortec 350 (SOLD)
-Father of three daughters who will also have something cool...
steemin_ehman is offline   Reply With Quote
Old 02-13-2007, 12:30 PM   #6
Captkaos
Captkaos's Avatar
Re: door handle
No, I am saying that you have to remove the handle from the vehicle to get the button out.
The rod comes off by removing the clip securing it to the latch. you can lift up on the tab on the piece locking the rod down and move it back then you can pop the rod out.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
