Old 02-12-2007, 08:56 AM   #1
gundyfan
pink wire question
Changing to a HEI style distributor can i use the pink wire to run the HEI?Also is the green wire for the temp sensor.
gundyfan is offline   Reply With Quote
Old 02-12-2007, 10:57 AM   #2
gyjackson
Re: pink wire question
You need a full 12+ volts to operate the HEI correctly. As far as the pink wire, you need to test it with the key on and see what it gives. Then have someone turn the ignition to the start position and confirm it still has 12+ volts. Of course in the off position it should be zero. Hope this helps, sometimes you will find there is a resistor in line that drops voltage to the coil. If that is the case you will need to replace the wire.
'72 Custom/10 SWB project... converting to 4WD
'67 Camaro rs convertible...waiting in line
'99 Ext. Cab Z-71 190000 miles on orig. trans fluid
'02 Black Z-71 burb..(wife's)
'92 Accord (daughter's)....Who want's my insurance bill?
gyjackson is offline   Reply With Quote
Old 02-12-2007, 10:57 AM   #3
kwmech
I always pull the factory harness apart and replace the existing resistor wire from the the bulkhead connector with a 12 ga pink. And yes the dark green wire is for the sender
Old 02-13-2007, 10:15 AM   #4
Huck
Huck's Avatar
To answer your question ---NO, do not use the stock pink wire to run your HEI. You need a heavier gauge and a full 12V DC to your distributor for your HEI to function correctly. Re wire to the HEI from your ignition for correct operation. You may also need to change your vacuum advance to ported vacuum depending on which HEI you use. Huck
Huck is offline   Reply With Quote
