02-12-2007, 11:18 AM | #1 |
3/4 ton Vs. 1/2 ton
I'm new to this body style and was wondering what are the main differences between the 1/2 ton and 3/4 ton? Is the body all the same and just different suspension and possibly frame? I have been trying to find a decent project truck and I talked to a guy that may have one and he said it is a 3/4 ton with a flat bed. If it is in pretty good shape i figured I could just pull off the flat bed and put a fleetside bed on it. I plan to bag the truck so am I barking up the wrong tree with this particular truck?
02-12-2007, 12:03 PM | #2 |
Cantankerous Geezer
Re: 3/4 ton Vs. 1/2 ton
The frame is a little heavier. Big difference is the suspension. If you are willing to swap out the suspension, get 73-87 1/2 ton parts. The entire front crossmember is almost a bolt-in, which will give you 5 lugs and discs. The rear will have brackets for leaf springs, but you can use leafs or coils, just use the right brackets.
Your biggest problem will be locating a decent bed. Look in the classifieds section for used, and the links section for new. Be ready for some sticker shock, though.
Fred There is no such thing as too much cam...just not enough engine. |
02-12-2007, 12:38 PM | #3 |
I am putting a 3/4 ton chassis under my 1/2 ton c10. The body and bed is a direct fit. I want the heavier suspension for towing and hauling, should the occasion arise.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
02-12-2007, 12:42 PM | #4 |
I was under the impression that the frames are the same with the exception of a few crossmembers.But the longhorn is completely different.
02-12-2007, 12:46 PM | #5 |
King of Rust
I have a 3/4 ton, finding rear suspension parts are tricky. About the only options are a few flip kits and re-done leafs. I think if your going to bag it you might do better with a 1/2 ton.
02-12-2007, 01:06 PM | #6 |
It all depends some have coils and some have leafs as stated before. Coil 3/4 tons are easy to make into half tons. The only real difference in the 3/4 ton frames from 1/2 ton frames is that the rear cab bracket on the frame is lower ant there is 2 braces in the same area. The front supension just do what fred said. Oh and welcome to the board from Oklahoma.
02-12-2007, 05:11 PM | #7 |
Thanks for the help. I hope to take a look at it tomorrow.
02-12-2007, 05:20 PM | #8 |
Sierra Grande Club
FWIW there are no 3/4 ton short beds. Not sure if it’s a big deal or not, just letting you know.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-12-2007, 05:46 PM | #9 |
Good to know that. I don't anticipate much trouble in cutting it down to fit a short bed though. As long as i measure 5 times and cut once.
02-12-2007, 07:58 PM | #10 |
Sierra Grande Club
A guy I know here shortened one the hard way. So yes it can be done.
s/t
02-13-2007, 10:00 AM | #11 |
Buying a 3/4 ton with the intent of converting it to a short bed 1/2 ton is ---well a lot of extra work so you need to make sure the body on the 3/4 ton is really nice and worth the effort. Well worn 3/4 ton suspension, axles, etc are not highly desired so selling that stuff might not work to your advantage. I would tend to look for a 1/2 ton with a solid cab first~~~. My .02 Huck
