Old 02-12-2007, 01:07 PM   #1
blazntn
69 control arms?
What other year upper control arms will work on my 69.?
blazntn is offline   Reply With Quote
Old 02-12-2007, 02:39 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: 69 control arms?
Also are 3/4 ton control arms the same as 1/2 ton?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-12-2007, 07:03 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
The LMC catalog says that all 1/2 ton 2WD 67-72's had the same control arms upper and lower. It lists 3/4 ton 71-72 as a different part, but I don't understand why they don't have a 3/4 ton listing for pre-71 trucks.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-12-2007, 10:01 PM   #4
Ram-Man
Ram-Man's Avatar
Try this thread but we didn't get any more info either.
http://67-72chevytrucks.com/vboard/s...d.php?t=225837
Ram-Man is offline   Reply With Quote
Old 02-16-2007, 09:56 PM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Interesting you mention LMC. I got both a 67-72 and a 73-87 LMC catalog so I could see parts listed for the 73-87 trucks that will fit ours and noticed that
According to LMC:
67-72 1/2 ton control arms are the same part as the 73-87 3/4 ton control arms. They use the same cross shafts and end nuts. The later 73-87 1/2 ton arms are different and have rubber bushing instead of the threaded metal end nuts like ours.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-24-2007, 05:05 PM   #6
LiveWire64
LiveWire64's Avatar
Are the arms with the big threaded end nuts better than the later ones with the rubber bushings, washer & nut?
55 Chevy small window.Have had 45 years.
66 FJ40 LandCruiser.Rock crawler/camping.
72 Chevy 10 Van,short wb,454.
78 Chevy 10 Van,short wb,350
77 Chevy Suburban. Silverado 20 Trailering Special.454,turbo400.Currently blown apart.
LiveWire64 is offline   Reply With Quote
Old 02-24-2007, 05:37 PM   #7
SCOTI
SCOTI's Avatar
The later arms w/the rubber bushings have a better ride quality because they offer more isolation/dampening.
Originally Posted by oldgold70c10
.....67-72 1/2 ton control arms are the same part as the 73-87 3/4 ton control arms. They use the same cross shafts and end nuts. The later 73-87 1/2 ton arms are different and have rubber bushing instead of the threaded metal end nuts like ours.
They use the same cross-shaft & bushings but from what I've read the BJ diameter is slightly larger (88-up truck lower BJ dia). I think this is how they do the 'cheap' 6-lug disc swaps (73-up 3/4 ton lower a-arm, 88-up LT duty 3/4 ton spindles, 6-lug disc brake rotors/calipers).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-27-2007, 11:02 AM   #8
GMC70c20
i did a post similar to this a little while back and found out that 67-87 3/4 and 1/2 ton upper control arms identical but lower control arms are differnet do to ball joints (other than that athey are also identical). Gm changed the design of there spindles in 73 to a shorter version so they used taller balljoints, and they also changed the tie rod diameters and lenghts.
GMC70c20 is offline   Reply With Quote
