02-12-2007, 05:38 PM | #1 |
Engine compartment, and identifying "stuff"
I'm posting this, hoping to get some answers. This might seem "n00bish", but I am trying to learn, just like others. Here are some pics, circled are some components I would like to know what they are exactly,and what they do. I am trying to get some info, I plan on putting some efans, and some other stuff in this spring or summer, in the process would like to "clean" up my engine bay as much as possible, make it look a little neater. Any advice or suggestions are much appreciated. Hope this thread helps others as well.
Thanks for any help.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native Last edited by pcmcobra; 02-12-2007 at 05:43 PM. |
02-12-2007, 06:18 PM | #2 |
Garage Queen Material
Re: Engine compartment, and identifying "stuff"
i dunno
the only thing I still have is the junction panel that is circled in red |
02-12-2007, 06:40 PM | #3 |
Insert Witty Text Here
The thing circled in green in the last photo appears to be your wiper motor.
Slonaker |
02-12-2007, 06:51 PM | #4 |
The One And Only !!!
The one in light blue is the harness plug for the starter, distributor and most likely alternator.
The Bright green one is a one way vacuum check valve. Can't make out what is circled in the yellow one.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-12-2007, 07:39 PM | #5 |
the yellow one is the vacuum switch to unlock the torque converter clutch on the auto tranny trucks (700r4 and 350c). dark blue one is a vacuum swith for the electronic spark control and egr. red is power junction block 12v+. light green is wiper motor.light blue appears to be cruise control wiring, can't really see what it's attached to.
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom Last edited by 73stepside; 02-12-2007 at 07:42 PM. |
02-12-2007, 07:44 PM | #6 |
Stepsides RULE
The red circled item is basically a main power terminal. Depending on the year of the truck and what powered accessories came from the factory/dealership, you may have just a couple things coming from it, or beaucoup crap. Most notably include the starter and alternator (one or both, I forget) as well as the main power line for your environmental controls.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
02-12-2007, 08:51 PM | #7 |
Sb 400 club
I know mu old 85 had all that stuff or everything but the greens and blue removed on mine. which had all the emission stuff taken off
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
02-12-2007, 09:15 PM | #8 |
Can someone tell me exactly what wire powers the fuseblock in the cab?
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
02-12-2007, 09:42 PM | #9 |
ureckmefixit2@cox.net
The red thing
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
02-12-2007, 09:47 PM | #10 |
It will be one of maybe two 10 Ga. wires most commonly red with fuse-able links on the end hooked to the large battery power supply post on the starter solenoid. One of these feed the red circled block.
02-12-2007, 10:16 PM | #11 |
alrighty then
02-13-2007, 01:02 AM | #12 |
Chevys Kick A$$
Some good info on here.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
02-17-2007, 05:49 PM | #13 |
Anyone else have some engine bay pictures or fuse block pictures? I have been reading up on some stuff, but still a little unclear on some things.
Maybe someone could recommend a book? Automotive wiring or something. Been googling for some answers...switched power and the likes. I have a good idea of what the many terms mean, like power when "on"...or "run"... On the fusblock, what's the best way to tap for a "switched" source? pics or diagrams would be nice. Hopefully soon, I'll be wiring up my efans, and putting on my 91 burb front end, adding some relays...I just want to know exactly what I am doing, not "act" like I do. Ordered a few items from mad electrical, that site has some very good info, but applying some of the info to my truck, sometimes is easier to me if I can see some examples. I want the wiring to look nice and neat, and for me to be able to make changes in the future for a motor/tranny swap. thx for any help all.
02-17-2007, 07:08 PM | #14 |
Thats all I seem to do is "ACT "like I do.
02-17-2007, 07:31 PM | #15 |
I bought one of these; http://cgi.ebay.com/ebaymotors/1986-...QQcmdZViewItem for my 74. It was a super investment, It shows everything about my truck.
02-18-2007, 11:32 AM | #16 |
Right on the line, baby!
Great question. Nothing noobie about it. GM had all kinds of pices on these engines and they change from year/year, altitude, and California.
Couple years ago I asked about the darker blue one. Thanks 73Stepside for the info!
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
02-18-2007, 12:30 PM | #17 |
Diesel Addict
The Thing circled in blue is the vacuum switch that controls the torque converter lockup. Follow that wire down and it'll go to the 3 or 4 prong plug on the tranny.
The thing circled in green is a check valve / vacuum restrictor most likely for the cruise control.
1979 C-10 Silverado w/ Olds 5.7L Diesel |
02-18-2007, 12:38 PM | #18 | ||
02-18-2007, 02:17 PM | #19 |
Diesel Addict
Follow the wire... see where it goes. On my 85 it went to the tranny.
02-18-2007, 02:25 PM | #20 |
will do
thx
02-18-2007, 03:25 PM | #21 |
I'm guessing Ziptar and 73Stepside both mean the same blue, but Ziptar's got the right idea, see where it goes.
