Closed Thread
Old 02-13-2007, 12:56 PM   #1
b.sharp
b.sharp's Avatar
Edited by Moderator
Edited by Moderator
b.sharp is offline
Old 02-13-2007, 01:47 PM   #2
jds319
Re: Driver door needed
You and me both.
1956 Chevrolet 1500 Task Force
2002 Texas Aggie
Project Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=212633
jds319 is offline
Old 02-13-2007, 02:03 PM   #3
Houston54
The doors on 1955 through 58 are identical. You should be able to trip over these at swap meets or ebay.
Houston54 is offline
Old 02-13-2007, 02:10 PM   #4
jds319
1955 to 1959 are identical. Driver's side doors, however, are becoming harder to come by.
2002 Texas Aggie
jds319 is offline
Old 02-13-2007, 02:39 PM   #5
b.sharp
b.sharp's Avatar
Well, I have two and neither one is very good. I could skin either if they make a skin for them. One needs the bottom inner panel and hinge pocket but appears to have some sort of patch over th original skin already at the bottom. The other I haven't looked at closely. It was in the bed of the truck whe I bought it. I assume it is bad, it has no hinges on it. I haven't seen any around my swap meets here in KY. What does a good door go for as far as cost?
Thanks again.
b.sharp is offline
Old 02-13-2007, 04:00 PM   #6
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks again.
You can buy the skins from brothers I just done this. inside and out. Now for the hinge that is a separate piece so make sure you order it. I had to do both doors and I really did not like the skins for the outside (seem a little thin to me) so I modified them. I only used the bottom and the side and I went a brought some 18 gauge sheet and and and filled it in. The inner patch panel is great please do not get the short one and try to save money its not worth it, get the larger inner panel and replace the whole thing its just a nicer patch panel. I did both of my doors , but my doors were toast. I had to buy 2 outter skins, 2 inner skins, and 2 hinge supports. With a little filler I should be good to go.
Kabwe is offline
Old 02-13-2007, 04:54 PM   #7
krue
Designated A-hole!
krue's Avatar
Re: Edited by Moderator
You need to subscribe and post a WTB on the parts board (if the info above doesn't work for you). For info on subscribing, click the support the board link in my signature.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline
Closed Thread
