Old 02-15-2007, 09:39 PM   #1
fast69
fast69's Avatar
73 spindals on 69 lwb
YOU GUYS ALL ROCK .CAN ANYONE TELL ME IF 73 SPINDALS WILL WORK ON A 69 LWB. THIS IS FOR DISK BRAKE CONVERSION. THANKS TO ALL AND GOOD LUCK AS WELL.
fast69 is offline   Reply With Quote
Old 02-15-2007, 09:53 PM   #2
68MoneyPit
Re: 73 spindals on 69 lwb
I am building 68 and have an 88 suburban with at 350,700R4. I was going to try to use the donor vehicles spindles,power window selonoids, brake booster, and steering box. Can any of you guys help us out. I need to know if any of you have used later model parts from these vehicles, and if there are any other parts that will swap. Thanks.
68MoneyPit is offline   Reply With Quote
Old 02-15-2007, 09:58 PM   #3
fast69
fast69's Avatar
Thanks For Helping Out. I Am Kinda New To Using Posts Like This.
Old 02-15-2007, 10:32 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
There are quite a few members that have swapped the crossmember from a 73-87 truck to thier 67-70. From what I have read it seems to be a fairly simple swap. I believe you can also use the 'Burb suspension from 88-91. I don't know if the brake booster will work. If it does I'm sure it will require some modification. I'm sure others will chime in with more info.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-15-2007, 10:41 PM   #5
arkracing
Weekend Warrior
If you don't use the entire crossmember you will need to swap the Lower Control arms from a '73+ truck - you will also need to make sure the upper ball joints are for a '73+ truck or up to '91 Burb and you need all the steering links/tie rods from the '73+
You could use the '69 Control arms with '73+ Ball joints but the steering stops on the lowers are different than your '69 - it is easier to just swap the whole control arm onto the truck than to "modify" the '69 steering stops to work with the later spindles
The power steering boxes will bolt in - unless you have a '67 Chassis (you may have to make an indendation for the steering box)
Brake Boosters are different - you will need to modify the firewall braket/rod of a '73+ to work properly (probably easier to locate a '67-'72 specific)
All of that stuff will bolt onto you're '69 X-Member.
Remember there were 1.25" rotors up untill about '77 and then there were 1.00" rotors and the option of 1.25" rotors - try to get the thicker 1.25" "Heavy Duty" rotors
Make sure to use a Master Cylinder and Proportioning valve from a '71-'72 and (Front Brake Hoses for a '71-'72 - if using the '67-72 Crossmember with later spindles, if using the entire 73+ crossmember than use the '73+ Brake Hoses - but you may need to modify your front hard lines)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 02-16-2007, 01:09 AM   #6
franky69c10
chevy runs deep
franky69c10's Avatar
Originally Posted by arkracing View Post
If you don't sawy the entire crossmember you will need to swap the Lower Control arms from a '73+ truck - you will also need to make sure the upper ball joints are for a '73+ truck or up to '91 Burb and you need all the steering links/tie rods from the '73+
some good info
thanks alot this will help me..
franky69c10 is offline   Reply With Quote
