Old 02-23-2007, 09:20 PM   #1
2nd_wnd
2nd_wnd's Avatar
Rearend gear ?
Ok. I pulled the cover off the rear diff and was hoping somebody could help me decode the numbers I got off the ring gear.
here they are as I read them:
381778 11 : 41 GM 2 - 72 1
I can get a picture if needed.
Thanks in advance
72 LWB
2nd_wnd is offline   Reply With Quote
Old 02-23-2007, 09:39 PM   #2
uncle
Re: Rearend gear ?
373.
uncle is offline   Reply With Quote
Old 02-23-2007, 09:41 PM   #3
2nd_wnd
2nd_wnd's Avatar
Re: Rearend gear ?
how do you come up with that?
is there something that visually says if its a posi or not?
i can spin right rear with left on the ground
72 LWB
Old 02-23-2007, 09:46 PM   #4
crazy longhorn
Fabricate till you "puke"
Re: Rearend gear ?
11:41.......3.73 gearset,cant help much with the rest tho.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-23-2007, 09:48 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Rearend gear ?
41/11= 3.73. You has an open diff.if you can spin one with other down.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 02-23-2007, 10:03 PM   #6
2nd_wnd
2nd_wnd's Avatar
Re: Rearend gear ?
Was really hoping for a posi diff. The truck was originally a 6 cyl. with 3 on tree. figured it was posi till today
72 LWB
Old 02-23-2007, 10:06 PM   #7
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Re: Rearend gear ?
pic of posi
Jason
jay_shy is offline   Reply With Quote
Old 02-23-2007, 10:34 PM   #8
2nd_wnd
2nd_wnd's Avatar
Re: Rearend gear ?
awww i see. mine has no springs
72 LWB
Old 02-24-2007, 12:11 AM   #9
ks147j111928
ASE Certified Spoon Operator
ks147j111928's Avatar
Re: Rearend gear ?
Luckily the build sheet was intact with this parts truck, 4.10 positrac axle!!! Also, aren't there tags on the diff cover that say something like "Limited slip gear oil only"? Easiest way to check is to jack up the pumpkin and spin one tire. Spin opposite, open diff. Same direction, POSI!! Can't wait to put this axle to work...
Frame and cab are for sale, has a 305 roller cam from 87-91.
It's plenty fun now though... I got it down to 'racing weight'.
My six is bigger than your eight
67 K20 292 +.060" SM465 NP203 3.73s
86 4Runner, the daily on 31s
85 4Runner, the wheeler on 38s
92 x-cab truggy project for 2017... tons and 42s and V8 power
ks147j111928 is offline   Reply With Quote
