02-25-2007, 10:34 PM | #1 |
sectioned crossmember pics
looking for pics of sectioned cross members. i want to section my 84 and im not to sure on where to start.
02-25-2007, 11:27 PM | #2 |
Sold! 2 days after finished
Re: sectioned crossmember pics
Do a search there is a hole thread on it.
02-27-2007, 01:32 AM | #3 |
Needs a Big Block
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
02-27-2007, 02:03 AM | #4 |
Until Seventy Times Seven
Here's a direct link to CaptKaos' write-up: http://www.captkaoscustoms.com/chopcross.html
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
02-28-2007, 11:02 AM | #5 |
Heres mine sectioned 1 3/8". If ya do it right you can't even see the seam.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! |
02-28-2007, 12:12 PM | #6 |
slammed87, how long did that take ya? Is it installed yet?
02-28-2007, 07:42 PM | #7 |
Outlandish Trends - FL
With a 1-3/8" section, do you still have to clearance the steering shaft?
-Bret 67 short-fleet sold! |
02-28-2007, 08:17 PM | #8 |
Mine was done by my friend who is a welder/fab guy. He has done a few of these before so i knew it would be done very well. I believe it took him about 7 - 8 hrs total. It is not installed yet. Still sitting in my backyard with a foot of snow on it lol. I'm just waiting to buy some headers and a few other goodies before i pull the motor to install it. I have checked and i am sure that i will have to raise the steering shaft a lil to clear.
02-28-2007, 08:18 PM | #9 | |
The rest of my steering wouldn't work w/a 1 3/8 section..... it was too much. I would have had to remove 1/3 of the u-bolt (& the nut) that secures the lower a-arms (the side that's inboard). Instead, I shimmed the c.member up 1/4" (for 1 1/8" total notch) & have about 1/8" clearance on the inner u-bolt/nut. This was after alot of grinding/clearancing.
02-28-2007, 08:43 PM | #10 |
I wish there was one concise, detailed write up on this mod instead of having to go through that monster thread with over 600 posts. Is there one that I am missing?
02-28-2007, 09:01 PM | #11 |
When i do mine i plan to take alot of piks and make note of all measurements and such. I'll post it all up later, if someone hasn't first.
03-02-2007, 12:23 AM | #12 |
you can safely go 1- 1 1/8 inches without hitting the drag link and **** on the LCA u bolts...me and my bro went 1.25 on his truck...but raised all the steering components .5 inches...
03-02-2007, 12:44 AM | #13 |
How did you go about this?
03-17-2007, 06:15 PM | #14 |
yea, how did you raise the steering comps.?
03-17-2007, 09:39 PM | #15 |
my bad guys....pm me if you need to know something cause I dont visit here too often...
cut sides of the frame where the box and idler arm bolted on and raised those pieces of the frame up. Then made fillers. |
03-17-2007, 10:14 PM | #16 |
03-17-2007, 10:42 PM | #17 |
