02-26-2007, 11:47 PM | #476 | |
Re: Dropmember in a 69 C10
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-27-2007, 08:47 PM | #477 |
will this back half be set-up for a corvette IRS?
02-27-2007, 10:22 PM | #478 |
I just pick up an the new issue of classic truck. I see the the dropmember made it in the tech section.
02-28-2007, 12:28 AM | #479 |
There will be a C4 version available shortly. The previous pics are for the straight axle version. The differences between the two variations are: the C4 back-half will not kick up as high as the straight axle version, the locating links will be a bit different, and the air suspension will be set-up with a rocker-arm and push-rod assembly on the C4 version.
02-28-2007, 04:47 PM | #480 |
Any new pics of the rear setup? What type of bag setup will it be? Does a 4 link setup work better or ride any better than a 2 link? Any idea how much?
Also started working on my dropmember install, I never got instructions so I used the Classic Trucks tech article! Any word on my rack? Rack notches- Heims? Thanks for all your help Nathan! Tony from Norcal |
03-01-2007, 12:11 AM | #481 |
Tony, that crossmember looks SICK!!! I sent you a PM on the parts.
Here's some more pics of the back-half... I will have it completed this weekend and will post more pics then.
03-01-2007, 12:21 AM | #482 |
Nathan,
Thanks for the response on the rack. Any idea how much the rear setup will be? Where will the bags be located in relation to the rearend? Over the axle or cantilever? And will it be bolt in or weld in? Did you see your tailgate for the burb in my pic? You still want that right? Also do you have a short fleetside bed that maybe I could partly trade the tailgate-hatch for? |
03-01-2007, 12:28 AM | #483 |
Those frame rails look like the could lay on some mudder tires. The bed will need some serious fab work to cover that up. How much bed depth will be left?
03-01-2007, 12:29 AM | #484 | |
I still want the gate... don't have a shorty fleetside bed that I can part with.
03-01-2007, 12:34 AM | #485 | |
It is set-up to have the bottom of the frame-rail (on the back-half) 17" inches from the ground at dump (that's with the framerails under the cab on the ground). That will allow up to a 31" tall tire... 22's with sidewall or a 24?. I can make em with less depth... for those who don't want it quite so extreme.
03-01-2007, 12:46 AM | #486 |
Thanks Nathan,
I know you're a busy man and i'm greatful for the responses. I'm definitly intrested in the back half! I hope i'll be able to use my slam bags with it! Tony from Norcal |
03-03-2007, 11:52 AM | #487 |
Insert Title Here
would that crossmember raise the engine enough to run long tube headers and still lay?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-03-2007, 12:53 PM | #488 | |
I don't think so. How far below the framerails do the long tube headers set on a stock crossmember?
03-03-2007, 03:33 PM | #489 | |
Nathan, how's the big block member coming along? Thanks guys Dan from Sun City, AZ |
03-03-2007, 04:49 PM | #490 |
The Big Block mounts are done. I shipped the first Dropmember BBC combo out this week. The motor mount tabs for the BBC set up 3/4" higher than the SBC and the mounts themselves are all the same. I am yet to mock it all up in a cab to see exactly where the fit issues lie. I am assuming some slight mods to trans tunnel where it meets the firewall will be needed (maybe 1/2" of clearance trimming) it might fit without slight trimming, but I am uncertain yet.
03-03-2007, 05:48 PM | #491 | |
I mean, what did I ever do to you . . . ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-03-2007 at 05:50 PM. |
03-03-2007, 05:57 PM | #492 | |
I just haven't heard back from the Unisteer guy... looks like I need to call him Monday!
03-03-2007, 06:13 PM | #493 | |
If I thought I could get one soon enough.... I heard there will be a dropmember & back-half picked-up soon for a TX delivery. You could just throw my stuff under his .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-05-2007 at 12:14 AM. |
03-03-2007, 09:31 PM | #494 | |
Village Idiot....
Never believe what you hear.... Soon enough? for what? There's this cool thing called Freight line service, they will deliver a drop member right to your door... go figure..... Last edited by n2billet; 03-03-2007 at 09:34 PM. |
03-03-2007, 10:08 PM | #495 | |
I thought I was getting my info from a half-way (or was that half-a** ?) reliable source. Thing about those freight services is they add to the cost . . .....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-03-2007 at 10:09 PM. |
03-05-2007, 12:15 AM | #496 |
Let me know what you find out.
03-05-2007, 03:02 PM | #497 |
that back half is sweet
03-08-2007, 07:15 PM | #498 |
i got one question does a 5.3 with a whipple charger fit with the drop member with stock hood?
03-09-2007, 12:51 AM | #499 |
There should be no hood clearance issues with this combo. You will however need to ditch the truck oil pan and get an F-body pan and pick-up tube.
03-09-2007, 01:17 AM | #500 |
Nathan,
What are my options as far as control arms? Should I order Djm's and have you modify or do you have another solution? The tire I want is a 285-35-22 which I beleive is close to 30" thanks Tony from Norcal |
