Old 03-01-2007, 02:28 AM   #1
Goodguytrucks
Spindles
What spindles will fit on a 1970 GMC 1/2 ton to lower it?
Belltech part #'s? Thanks for the help
Goodguytrucks is offline   Reply With Quote
Old 03-01-2007, 08:02 AM   #2
Rokcrln
Rokcrln's Avatar
Re: Spindles
I have both Belltech and ECE's and I have to say I feel the ECE's spindles are a better piece for our trucks!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-01-2007, 10:26 AM   #3
Goodguytrucks
Re: Spindles
Well I talked to a few different people and some say Belltech #2400 and other say Belltech #3120
Old 03-01-2007, 10:54 AM   #4
Re: Spindles
Go ECE.The last I looked at BellTech(before ECE)they requires adapting at tie rod ends.I`ve since heard the quality of casting comes nowhere near ECE quality.I use ECE...bolt-on easy.As far as what ones?Any pre`73 if you want 5-lug.They make 6-lug disc spindles,too.
Old 03-01-2007, 11:12 AM   #5
boraxman
Keepin an eye out
boraxman's Avatar
Re: Spindles
You can also go with 71-72 factory spindles and use dropped springs for up to a 3 inch drop...could be more cost effective, actually the way I went.
*I know dropped spindles are the better way to go, this is just some extra info.*
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-01-2007, 11:44 AM   #6
Goodguytrucks
Re: Spindles
Well maybe I will just have to go with the dropped springs ...I am looking at a 3"-3 1/2" drop in front and about 6" in rear.
Old 03-01-2007, 12:48 PM   #7
dingo_dan_22
dingo_dan_22's Avatar
Re: Spindles
My Belltechs were #3120, My truck is a 71' so you'd have to swap upper ball joints for a 71's. You'll also have to convert to 5 lug rotors
There's an application guide on belltechs website. They list the spindles as 71'-72'
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop
dingo_dan_22 is offline   Reply With Quote
Old 03-01-2007, 02:28 PM   #8
Goodguytrucks
Re: Spindles
I was mistaken my Truck is a 1971 and it does have rotors and disc brkaes on the front.........I don't know why I thought it was a 1970
Old 03-01-2007, 02:49 PM   #9
dingo_dan_22
Re: Spindles
then the'll bolt right on. 15" wheels might rub on the lower a arm but u just got to grind the arm a little bit.
